Question about Sharp AR-M237 Copier
JUST GOT A USED SHARP AR-M237 - NEED TO CHANGE IP ADDRESS BUT IT HAS AN UNKNOWN PASSWORD - TRIED CHANGING LOCAL MACHINE TO LOGON THRU BROWSER - BUT CANNOT CHANGE IP BECAUSE OF PASSWORD - PLEASE HELP
  • 1,110 Answers
The factory default administrator username and password are admin and Sharp
Posted on May 12, 2010
  • kellym9236 Dec 27, 2010
    where do I use that ?
    Problem Solver:
  • 19 Answers
Should be able to reset admin password using simulation 24-9
Posted on Aug 18, 2010
    how do I run that I have no clue what that is and how can I find my ip address when I can't login casue I don't know the code in custom settings?
  • Jim Brown Oct 25, 2012
    #*C* wil get you in service mode that is where you put in 24-9
How do I set up an address to the frequently used addresses tabs on sharp ar m355n?
on the web page(accessed by typing the machines' IP address into a web browser)
click destination, the username is admin, and the password is Sharp
then put a check next to the person's name, and click edit
then check the "Frequently used" box on the page and click submit.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp AR-M355N Copier
Sharp AR-M257 clearing user names in scan feature
Please log in machine with you browser with machine ip address
and user name and password is admin and Sharp and go to address book and remove anything you do not want.
Dec 04, 2013 | Sharp AR-M257 Black and White Copier
Attempting to print to my Sharp ARM237 Network printer. It gives me the error Unable to access server. Check server address on device web page" . It used to be networked then I moved the loacation...
you must put the right IP adress for the machine: from the menu
  1. choose system setting
  2. Network settings
  3. IP address setting
  4. copy the the ip adress from your computer and type it in the special field
Dec 06, 2010 | Sharp AR-M237 Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Change email address
You'll want to access the device webpage. Open web browser on your computer and type the IP address of the machine in the address bar. On the page that comes up to the left you should find admin mode. Type the user name and password, the default is
User name: admin
Password: Sharp
Case sensitive
Click the Destination link, find your name you want to change and click the edit button.
There is a checkbox to add that destination to the Frequently Used tab, if you uncheck that box it will remove you from that tab.
Nov 28, 2008 | Sharp AR-M450N Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
Sharp AR-M237 Copier Logo
1,517 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
