Dvd problem help!
When i put a new disc in it said load and then no disc why. when i put anouther disc in it says the same thing and its not that old. I got it at wal-mart after xmas but i havent played it verry much . please help some one!!
    Genius:
  • 1,550 Answers
Compra un disco limpiador de lentes de laser e insertalo a ver si eso soluciona tu problema.
Posted on Mar 29, 2008
Problem with 'loading'
that is the laser lens , it is dirty,
you will have to cleaned use a q tips with wood alcool
dont aply to much pressure on it while wiping it
its should works if it not
that is the laser it self replaced the laser assembly
hope that will help
regards Alan
May 16, 2010 | Spectroniq PD-1100 DVD Player
Every time i try and put call of duty on the xbox it wont load it keeps saying loading dvd but its not a dvd its a game it was working fine yesterday
The same exact thing has happened to me with Call of Duty. It is extremely frustrating. If the Xbox is working with other games and not Call of Duty, then it means that the call of duty disc is ruined. You simply have to buy a new one. Before buying a new one, however try cleaning the disc with disc cleaner, because that has worked before. Good luck, and any further questions let me know so i can help you resolve this issue.
Jan 20, 2010 | Microsoft Xbox 360 Console
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
Hi -- my toshiba SD3990 model DVD player won't
Your DVD player is fu.k.d up.  These things are made so cheap now a days that it is more trouble to try to fix the thing, than going out and buying a new one.  You can try running a disc head cleaning kit through it first to see if that helps.
Nov 23, 2009 | Televison & Video
Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Apr 22, 2009 | Audiovox D1917
Vcr works but dvd disc of go video solely say loading
There are a few different things that you can try. First make sure that your discs are clean before you put them in the player. Even if the disc is new I would recommend cleaning the disc off. The second thing that you can try is a DVD player reset. You can do this by unplugging the player for about 5-10 minutes. Then plug it back in and try the disc. If that does not help I would try a DVD head cleaner in the player. If all of these things do not work, it is most likely an issue with the player.
the laser inside may be having the problem or the optical sensor inside the player is not proper.....
if after all the above said procedures fail kindly contact ur manufacturer.
thank you
Apr 06, 2009 | GoVideo Go Video DVD/VCR Combo
Atapi dh20a4p problem
OK... see if this:
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly K000888950 will work for you?
See eBay: 272402441049
$20 NEW ~ Including shipping from Denver.
The ONE thing that does bother me about this Auction is the word "BEZEL"... is it just the BEZEL without the actual drive? Please MESSAGE the seller and ask!
Final note: Be VERY careful about DVD Drives that are listed as "NEW" (other) ... MOST times that decodes to USED!
Anthony
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly...
Nov 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
Dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Mar 14, 2009 | Samsung DVD-V3500 DVD Player/VCR
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
