Question about Ryobi Cultivator
ROYBI RY60514 quit running after about 1 hr. has fule and spark Tried a shot of starting fluid in air intake didn't even get a sput???
Yamaha blaster 2001
No fuel or no spark. Quick test: spray some starter fluid into air intake and try to start it. If it runs and then dies, you've got spark but no fuel. If the bike quit with no prior symptoms, check spark plug wire not knocked loose, fuel filter clogged. (You do have gas, right?)
May 20, 2014 | Sport & Outdoor - Others
Pontaic not fire while reading code p0463
Something in your ignition system or circuit must have quit. The code does not seem to be related. Have you checked for spark?
There is a good read here on the code-a complete run through of what to check.
.there is a good read here on TTT
Jan 14, 2014 | 2002 Pontiac Montana
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Cranks, why no start?
Usually because of an ignition or gas related problem. You need to check for spark at the plugs and for gas at the engine.
A quick method to check for a gas problem is to spray some starting fluid into the air intake on the throttle body. Take off the big boot from air filter housing to the engine, spray a shot of fluid into the engine, then try to start it. If it fires up and tries to run from the fluid for a few seconds, then you know it is a fuel problem. Maybe the fuel pump has quit working, or the fuel filter is clogged. If both are good, maybe a fuel injector circuit problem, less common but possible.
If nothing happens from the starting fluid, it may be ignition related-not getting spark. Pull off a spark plug wire from a spark plug and hold the plug wire end terminal about 1/4 inch from an engine bolt or ground. Have someone crank the engine over from the key and watch for a consistent, blue, snapping spark. If no spark, test a few other plug wires to verify no spark at all. So it is not just one ignition coil not working, but none of them produce spark. No spark means the ignition system needs diagnosing. Sometimes it is the ignition control module that goes bad-it can be tested at any parts store. Post back and we can go from there.
Jan 31, 2013 | 2000 Isuzu Rodeo
Car stalled, will not start even with a shot of starting fuild in intake.
check fuses and fusable links,check to see if you have spark
Mar 14, 2012 | Cars & Trucks
Engine turns over but wont start? it has spark! and fuel!
Pull out # 1 spark plug and put back into plug wire, rest on motor block so that end of electrode is against metal. turn motor over and have a finger or compression gauge in # 1 cylinder, check to see if spark occur at same time as compression (compression will blow air past finger or raise gauge). When you say it has fuel do you mean gas tank has fuel? Are you sure fuel is getting to the cylinders? are plugs wet with fuel? Does it turn over but kinda thumps or backfire (Caugh)? Check the spark and compression first. if they don't happen at same time, the timing skipped or belt broke. if all is good pull plugs and inspect, could be flooded (WET) from fuel. either replace or spray with starting fluid and compressed air to dry them. spray starting fluid into air intake if starts then stalls, try again, if same thing happens then you have a fuel problem. try these suggestions first 1/2 hr time table, hopefully sucess, if not it sure indicates fuel.
Jan 10, 2011 | 1995 Subaru Legacy
! have a Troy built mower with a Honda engine, it quit running and will not start. I changed the spark plug, it ran for about one hour. Now the mower will not start.
Hello. If the gas has been sitting all winter, remove it with a siphoning bulb and put in brand new gas, not even gas that you have been storing all winter. Also, change your air filter. Finally get a can of starter fluid and a helper. While one person squirts a bit of starter fluid into the air intake [near the air filter] the other person starts it and use more squirts of starter fluid to keep it running. Joe
Apr 09, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Trimmer model: Sears 358.796121: no start
Could be a faulty kill switch not allowing it to start, sounds like you covered all the things I would check.
Jul 09, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi Cultivator Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
