Question about Sony Playstation 3 (PS3) Console
No game reading
My playstation 3 which was recently updated started to stall in the middle of a game and now will no longer read a disk at all
My ps3 worked fine util i installed the 2.10 version update,and then it quit reading games [blu ray movies and regular dvd's would still play] i called sony and the guy told me to restore system setttings and install version 2.20. after i installed this version from their website my ps3 would not read anything. if you still have proof of purchase sony will send you a refurb. but my guess is after you install the same version again you will still be sol and after your 1 year warranty is up sony will not have any else to do with you[xbox offers a lifetime warranty] now i have an xbox360 and a $700 freaking paper weight. THANKS SONY!!!
Posted on Mar 29, 2008
SOURCE:
My ps3 will not show i have a disk in the console. I tried cleaning the lens still no disk. Help?
The problem is that the lens of your ps3 is either dirty or weak that it can no longer read any disc, i advice that you get a lens cleaner to clean the lens of your game, if after cleaning, problem persist, replace the lens on your ps3 so that your ps3 can continue to function as it use to function before.
Replace the lens on your ps3 and you will see that it will start reading discs.
You can also try the below procedure before replacing the lens,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
Game freezing in middle of game also not reading disk
This is a very common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are typical of a failure of one or both of these lasers.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa.
Jun 21, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: wont read disk...
This is a common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer 'see' or read the game disk properly.
The symptoms you describe are quite typical of a failure of one or both of these lasers.
May 18, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: doesn't read disks...
This is quite a common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer 'see' or read the game disk properly.
May 17, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: my ps3 slim wont read any disks...
This is a very common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer 'see' or read the game disk properly.
May 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont play a disk
make sure the disk is clean - clean it with a clean cloth or tissue in a circle around the middle of the disk. otherwise, try returning the disk to the shop which you bought it from
Jul 23, 2009 | Sony PlayStation® 3 (60 GB) Console
Disk not reading
I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 DOSENT READ MY GAMES
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
Playstation hard disk not reading
i had the same problem with fallout 3 and then i updated my system with 2.52 and then the blue ray lense quit reading so now i can't load any Ps3 games.
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
