Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
DEFROSTED WATER DOES NOT DRAIN TO PAN
Defrosted water drainage
Water from defrost cycle does not drain into pan remains in freezer and is refrozen under floor pan in freezer.
  • Whirlpool Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) and the bottom panel . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER ( ground wire is good ) solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 12, 2010
Leaks water on the floor from the freezer.this is a maytag.
check drain line inside freezer. There may be a problem with circuit board that controls the defroster. Most likely the drain line to the pan underneath is clogged. causing the defrosted water to back up into the freezer.
Sep 20, 2014 | Refrigerators
Water accumulates in the bottom of the freezer, model FRS26ZRG, then melts out onto the floor
the water drain is clogged, when a freezer goes in to a defrosting cycle it MELTS the excessive ice build up and the water drains throug a drain (usually in the back of the freezer) than goes in to a pan under the freezer to evaporate until the next defrosting cycle, so check the pan if it's not full of dust or debrie (cat toy HA!) as well...
Cheers!
Aug 31, 2011 | Blenders
My automatic defrost freezer in my frig does not drain the water down to the drip pan. Instead the water is coming through vents inside the frig directly under the freezer. this is an older Amana. We...
If the drain isn't stopped up than the water isn't draining into the drain.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Aug 11, 2011 | Refrigerators
Our Crosley CS20 refrigerator/freezer has been dripping water on the floor and the bottom of the freezer has been full of ice. We defrosted the freezer, taking everything out of it, and saw there was ice...
Defrost drain is frozen. Poor hot water around it until it is clear. You will most likely have to take inside back wall of freezer off to access defrost drain. While you have it off, inspect metal pan to be sure holes aren't rusted in it. Some are aluminum, but some are steel.
Sep 05, 2017 | Crosley Refrigerators
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
I have a Maytag side by side and water is leaking on the floor and I have a big build of ice on the bottom of the freezer. Can you tell me how to fix it?
Unplug the refrigerator.
Remove the food and shelves from the freezer side.
Carefully break up and dispose of the visible ice. There is a drain pan on the lower rear of the freezer. Defrost the ice in this pan with a hair dryer.
Once the ice is out of the pan the drain hole that goes through the bottom of the pan must also be defrosted.
After the drain hole is defrosted pour a mixture of 1/4 cup bleach and 1 and 3/4 cups hot water through the drain hole.
Jan 17, 2010 | Refrigerators
Water leak from Styrofoam insert of Kenmore 79202
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 31, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
641 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
