Question about Dell E153FP 15" LCD Monitor
When turn on monitor says video cannot be displayed
  • 506 Answers
Check to see if the Video cable is properly connected to the system. Remove and connect it properly and tighten the two screws properly. Also confirm that there are no abnormal beeps when you power on the system. If there are beeps confirm that the RAM is ok. The system should come on if these things are ok.
Posted on May 12, 2010
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
The display has turned yellow.
Possibilities:
* bad connection of video-cable to monitor
* bad connection of video-cable to computer
* bad video-cable
* bad monitor -- connect to a different computer to see if it works, or displays the same symptom
* bad video-card -- connect a different monitor to see if the symptoms persist
It's probably time to responsibly-recycle that CRT, and spend $100 to buy a new 19-inch LCD monitor.
Oct 23, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Monitor going berserk
This could be due to corrupt display drivers on the notebook or the video card is going to die. Try updating the graphics drivers on the notebook and check for the issue.
If the issue still persists, then to isolate the exact cause of the issue, I recommend you to connect an external monitor to the notebook and check for the issue on it. If external monitor works fine, then the issue with LCD display screen of the notebook. In case, if the issue persists on external monitor then it states that the video card of the notebook is going to die.
To connect an external monitor to the PC, follow the steps listed below:
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
May 28, 2010 | HP Pavilion dv6000z Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
Step 2 :External Monitor
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
May 20, 2010 | HP Pavilion dv6000z Notebook
I have hp dv6500 i update my bios and my display is total black just light blinking pls help me wht i do ?
This could be due to hardware malfunction of the video card on the notebook. To isolate this, perform the following steps.
*** Hard Reset ***
After performing the above step, if the issue persists, then connect an external monitor to the notebook and check if the display comes on external monitor or not.
*** External Monitor ***
No signal to monitor. Cable is fine and so is the Video Card -
your motherboard may be going out is your keyboard also acting crazy
Aug 15, 2009 | Impression Products Impression 7LSP 17"...
Display problam
  1. Make sure that the monitor is turned on and has power. Make sure that the display's power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Check that all video cable connections to the computer video port and to the monitor are properly connected.
  3. Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
  4. Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
  5. Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
  6. turn off the system and check the ram..
  7. Reset the computer...
Jan 28, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Dell E153FP 15" LCD Monitor Logo
53 people viewed this question
Alun Cox
