Question about La Marzocco FB-80 Series 3 Groups Coffee Maker
Water dripping from my boiler/dispensing pressure gauge
La Marzocco 3 group (220v) Water is dripping from boiler/dispensing pressuregauge
    President:
  • 1,618 Answers
If it is leaking from the gauge then have it replaced ASAP. It is easy to replace, just make sure machine is turned off and cooled and water is turned off.
Posted on Sep 12, 2010
La Marzocco Linea 3AV...water is coming out of group heads but is not hot. The boiler for the steam is hot. Help?
Your front brew boiler likely has a dead heating element or there is a problem with the electrical system for the front boiler.
Aug 03, 2011 | La Marzocco FB-80 Series 3 Groups Coffee...
Zero steam from steam wands. No pressure.
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
Apr 14, 2011 | La Marzocco Linea Series Group 3 Espresso...
How do I increase grouphead pressure on la marzocco linea 2 group?
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
Dec 16, 2010 | La Marzocco Linea Series Group 3 Espresso...
The machine is not heating
Make sure there is water in the boiler, then check the thermostat on the boiler.
Sep 09, 2010 | La Marzocco FB-80 Series 3 Groups Coffee...
Expansion valve won't regulate pressure. how do I remove/clean/adjust this valve?
The only thing the expansion valve does is open when the pressure gets to 12 bars when the coffee boiler is heating or when you are backwashing the groups. If you need to adjust wait until red light comes on to say coffee boiler is heating then if gauge is going beyond 12 bars turn end of expansion valve to left to keep it at 12 or right to take it to 12 if it is lower, before doing this make sure pump is set to 9 bars.
Aug 21, 2010 | La Marzocco Linea Group 1 Espresso Machine
La Marzocco GB 5, 2 group head boiler not starting. It says coffee boiler 1 30.8 C. Please help
New machine? check the thermal reset on top of the left group head. Press the red button and see what happens.....
Aug 17, 2010 | La Marzocco Linea Series Group 3 Espresso...
La Marzocco Expresso g3 how do you reouble
Check the thermostat on the top of the back boiler, if the red pin is up then, make sure that there is water in the boiler then push in pin and turn machine on. Now comes the exciting part we have to find out why the boiler overheated, is it because the elements are damaged or the pressure stat is not working properly.
Nov 05, 2009 | La Marzocco Linea Group 1 Espresso Machine
Grouphead not dispensing water
Remove the shower screen and press button to brew, if water flows the the holes in the screw/diffuser is blocked, if water does not flow then the blockage is at the solenoid or within the group head chamber. This problem I have notice when someone brewed without the shower and screw in place.
Jun 29, 2009 | La Marzocco Linea Series Group 3 Espresso...
La Marzoca 2 group dispense pressure only around 2 or 3
Pump pressure is adjusted at the pump. There is a nut or screw next to the water inlet that is used to change the discharge pressure. This assumes that your pump is running. Your pressure of 2-3 bars sounds like the pump is not running at all. Put your hand on the motor to determine if it is running. If it is not running then that is the problem you need to diagnose. If it is running then it could be the pump or coupling.
Jan 28, 2009 | La Marzocco FB-80 Series 3 Groups Coffee...
La Marzocco FB-80 Series 3 Groups Coffee Maker Logo
209 people viewed this question
Top La Marzocco Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
