Plasma screen - no picture
I just started getting a message on my sony plasma screen - no video input - I can't see a DVD either - could this be a cable connector problem or is it a problem with the actual screen - I have bypassed the vcr & set top box - still nothing?
  • 149 Answers
You may have wron resolution in your tv go to standar 480 and try
Posted on Mar 29, 2008
Troubleshooting a Fujitsu plasma screen. No picture, or audio.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 29, 2015 | Fujitsu Plasmavision 42" TV
When i connect the DVD or Playstation to the AV of the HITACHI plasma ( model 42pd580dta ) I get a fickering black n white screen, no sound, you can just see the dvd or ps screen..Its like its not tuned...
Unplug foxtel three video pins cable and plug yellow video cable of dvd then play it, you will get correct and clear picture in video input.
You can not plug composite and component video at same time in video input of tv, that is cause of your problem.
Thanks
Jul 31, 2010 | Televison & Video
My 2003 Sony Plasma television gets no screen. I was watching television when the image froze. I turned off the television, and turned it back on. I can hear the audio from the cable, but I get no picture....
Check all the video inputs. If non of the inputs of video work you need a new Q board, However if your screen doesn't work at all shows no signs of life and you can't access the menu then you will need a new B board.
Oct 30, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
When i hook up dvd player to a insignia plasma tv i get a picture & sound but it is in black&white.how do i get to be color
if you connect composit video from your DVD player to the "Y" jack of the tv then you will get only a black and white picture .. the composit video out of your DVD has to be connected to the composit video input of the TV .. or if you have component outputs on your DVD then you can hook those up to the "three" component inputs of the tv .. (you have to have all three hooked up plus 2 audio cables ..
Oct 23, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Connecting dvd?
If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
Jul 01, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
DVD Connection to sony flat panel
hi there mate i have a sony plasma pfm42x1 i being trying 2 conect my dvd and amp to the tele i dont know what plugs i need could u help me please rodney from australia
Feb 18, 2008 | Sony PFM-42X1 Plasma TV
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
