Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnia 551 ft heater
Can u tell me why we have to put water in the bottom of our heater and where we can obtain a heater manual for this particular model
    Problem Solver:
  • 5 Answers
Give me all your info on the heater and i will see what i can do. as i deal with rennia on a busness leval.
Posted on Mar 31, 2008
The water is required to increase humidity in your room. It is not required to operate the heater, but increase the confort level as the heater also dehydrates ( reduce the moisture level of ) the air .
Posted on May 02, 2008
SOURCE:
My New A.O. Smith water heater is showing an ECC code what can I do
Hello, Frazell -
If your A. O. Smith water heater is new, it probably came with an owner's manual. Find where you put yours and check the manual to find out what the ECC code means.
From an owner's manual for a particular A. O. Smith Hybrid Heat Pump Water Heater, the code ECC means the heat pump compressor is not functioning.
Source:
https://www.manualslib.com/manual/755258/A-O-Smith-Hybrid-Electricheat-Pump-Water-Heater.html?page=17#manual
Best wishes.
Jan 19, 2018 | Water Water Heaters
Rinnai energysaver 551 ft starts but won't stay running
Those water heaters are very sensitive to flow rates. The service manual appears to be here: http://rdjxmmyvbu.blogcu.com/rinnai-551f-service-manual/13623970
But there is no guarantees
Jul 24, 2016 | Rinnai Heating & Cooling
Rinnai r85 exterior propane tankless water heater makes knocking/clicking noise. seems it tries to start with clicking noise then no fire in burners then cycles again. no error message. have two rinnia...
on start up the clicking noise is normal as well as knocking noise ....one important item with fan , if the fan was removed cleaned and then reinstalled with power to unit could have ruined the fan and it will have to be replaced..... Cant tell you why is wasn't firing before with no codes...other than flow sensor not working( most likey stopped with sand fragments or trash) the flow sensor detects hot water demand and ignites heater and if clogged it will not light up but doesn't give error code and the water running through hot side will be cold..... flow sensor is a turbine that detects water movement and lets heater light..... may want to get serviceman to check this out and clean turbine.... hope this helps...
Mar 27, 2014 | Heating & Cooling
RINNIA CODE 02
Google the brand and model number for the operating manual and look up the code and it's meaning.
Aug 23, 2013 | Rinnai E110CP Condensing Combination Gas...
My rinnia moldel 2532 wont kick on
Those units rely on a flow sensor. If you have water pressure problems it wont activate. If you have hard water, the flow sensor could be bad.
Apr 16, 2013 | Rinnai Water Heaters
Very hot around freezer door from top to bottom of cabinet about 1 inch wide all the way around
That would probably be from an anti- sweat heater the designers put there to keep condensation from forming in humid climates. There may be a switch to de-energize this heater, check the owners manual.
Jun 26, 2011 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Faulty Fan in Rinnia 2000 gas heater
You are right
The gas valve has to come out to remove the fan.
Get a gasfitter to do it.
Jul 08, 2009 | Heating & Cooling
Need a diaphragm for my rinnia water heater reu 56es
Sounds like tank froze with water in it. Have you checked the connections on the top of the heater they could be leaking also i would check water lines around that area for tees or 90 degree fittings. You can pull heater out and try to check it out. you can fill water heater with water to check to see if heater has a crack in it.
Jan 18, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Code 12 on my water heater
code 12 is low gas pressure, or that the flame sensors are not picking up a flame, try removing the flame rods, in a rinnai infinity when you pull the cover off they are right in the middle, you can use a file to clean any carbon etc off,
Jul 14, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
172 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
