Question about Maytag Neptune MDE5500AY Electric Dryer
Squeeky noise in the back of dryer when running?
Neptune dryer MDE3000AYW started to make a squeeky noise in the back of dryer when running. Made sure that it was leveled. it's missing two rubber feet, but put on rubber feet and it stills makes the noise.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryersqueeky noise in the back of dryer when running? - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
Testimonial: "Thanks for your response to this matter, as I thought that it was exactly what you said, but needed a solution from some one that knows. thanks"
Maytag neptune dryer model mde3000ayw wont start
If it only runs with start button held in then you have a problem with the door switch. Check to be sure the wires are on it. Here is the switch to order in case it is bad.
Nov 29, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune MDE3000AYW serial no. 12307603UU. The dryer will not turn on. I can hear the timer clicking but when you push the start button it will not start. The door is closed. I have...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer making squeeky sounds
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 14, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have the MDE3000AYW gas dryer and the roller
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag MDE9316 Dryer
Maytag MDE3000ayw. When I press the start button, there is a humming sound, but it won't start. Is this likely a problem with the start button, or the motor? The belt is fine.
It's not the start button if it responds to the button. Make sure the motor spins freely. If so, make sure you have voltage going to the motor. If so, check the start capacitor (if equipped) Good luck.
Mar 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Cold blooded neptune
check the hi-limit switch on the element case and the cycling switch also there for continuity,then check the thermal fuse for continuity its in the exhaust vent area
Mar 03, 2010 | Fisher and Paykel DEGX1 Electric Dryer
- very loud squeaking sound
Hello JewettKann,
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #17B on the drawing) Called a sound damper pad on some models.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE4000AZW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-LAUNDRY&diagramPageId=00004&componentDescription=DOOR&documentId=M0402169&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
If you can get the complete model number off your dryer, you can select the exact line drawing and parts list at the link below to make sure you're looking at your exact model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mde4000&=part+number
I hope you find this Very Helpful and best regards!
Dec 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Metal on metal sound when the dryer is running
I have the same problem and I'm sure its the belt tensioner pulley
Jun 06, 2009 | Maytag Dryers
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
508 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
