LG WD-8013F wont spin
The washing machine goes through the rinse cycle but does not click over to the spin cycle or pump the water out. Tried switching off and putting it through the spin rinse cycle only it rinses fine but will not drain or spin.
Pump issue? Computer issue? Can anyone help?
  • rayor Apr 22, 2008
    Mine has lasted five years and has just developed the same problem.  I'll let you know as soon as I have an answer and likewise if you beat me to it.
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
Model WD-8013F. Why does it continue filling after wash cycle should start?
water level sensor may be faulty, or the air tube that works in conjuction with the sensor may be plugged. check out repairclinic.com or appliancepartspros.com for videos on this issue and fixes.
Jul 17, 2015 | LG Washing Machines
I have an LG front loader - model WD - 804 90TP and the machine is working but it gets down to 6 mins to run the spin cycle and then goes up to 14 mins and then back down again and carries on in that cycle...
You need to check the inlet valve for good flow of the water as a SLOW water pressure can increase the timing for rinse and spin.
Similarily the DRAIN pump/valve must be checked as if this is clogged then the drain flow will be LOW and the timing will extend for full drain. Remove and clean the drain pump and it can be the reason that the clothes are still wet.
Finally check on the controller for the proper timing of the cycle.
Tips on Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | LG Washing Machines
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
Washing Machines Logo
719 people viewed this question
Top Washing Machines Experts
