Question about Frigidaire Kitchen Ranges
Should the top of the range get too hot to touch when boiling water
  • 4,066 Answers
The eye you have on to boil the water will get too hot to touch but the rest of the surface should not get warm.
Posted on May 12, 2010
CAN I USE MY AMANA ELECTRIC SMOOTH TOP RANGE FOR PRESSURE CANNING?
Yes, but a boil over could be potentially disastrous- when the water hits the hot glass top bad things can occur....
Jul 24, 2016 | Amana Kitchen Ranges
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Correct installation of thermostat for 2004 dodge 1500, 4.7 engine, runs abnormally hot, just a tad over middle temperature range, after being run top hose very hot to touch, bottom hose cool, thanks in...
you know when its wrong the guage goes to the top,then drops.the temp guage is notoriously wrong on most cars,so if your not losing power,water,leave it.(the top hose is hot,about boiling point,the botom should be just warm)thats what the radiator does......
Jun 17, 2010 | 2004 Dodge Ram 1500
Smoke pours from under the range top when a burner is on
[UPDATE} I gathered up the courage and left the element on for a while, carefully using aluminum foil in place of a drip pan. No bad smell. The initial odor was just the residual burning off of the last of the rust/dust. I was worried about directly contacting the hot element with the foil so I made sure it didn't directly touch the element but that was probably an unnecessary concern as aluminum foil has a very very high melting point
Feb 18, 2009 | Kitchen Ranges
Will burner get too hot
Hello Pinewood7. The issue here is concern from what you have heard. Don't worry! All you are doing is boiling water. The system will allow constant heat for what you are doing. Use this as a test. Put your largest pot on the top full of water and set on high. Attach your thermometer to the side and see what happens. I know several people who use these tops for canning with excellent results. My sister in law has had yours for years and not an issue with jams. Hope this helps with your concerns.
Aug 09, 2008 | Jenn-Air Expressions AR141 Electric...
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Wo'nt boil water
PS The four asterisks are supposed to read "k n o b". There is an apparemnt problem with the website's text checker program.
Mar 10, 2008 | Maytag MER5770 Electric Kitchen Range
Kenmore smooth top - cooking problems
Smooth tops take a little geting used to than a coil top range....Make sure you have good flat cookware. NO GLASS COOKWARE. (ie vision ware.) Once the burner is set to high, it has to heat the glass, then the pot, so it does take about 2 min loger to boil, If you want to simmer, then i suggest bringing the item to a rapid boil, and then cutting back the heat to below the 1 on the range. and adjusting from there. All smooth top glass ranges do work in this manner. Most people can adjust to the switch, but not everyone can. there really is no problem with your range. BTW i work at sears, and i am surprised that no one helped you.
Dec 20, 2006 | Kenmore 96412 / 96414 / 96419 Electric...
Kitchen Ranges Logo
47 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
