Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is flashing 2 f
I put a load of wash in the washer and when I went to switch it to the dryer the washer was flashing 2 F I cant find my manual to see what it is trying to tell me. Can you help please? Thanks Julie
  • 5,911 Answers
"F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are NOT listed in the Owner's Manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Posted on May 12, 2010
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Hello, I have a frigidaire washer. I loaded it up and started it - the water went in. But after that, it just stopped. I tried it again, tried different cycles, still doesn,t work. The Start light is...
Well I'm not an expert but I have had problems in the past but it was with my top loader washer. Sounds like it could be a number of things: could be the transmission, or could be a switch or an electrical problem (thats the problem with these new digital washers/dryers!). You will definitely have to call a technician unless you can get a manual and try to fix it yourself. Mine is a year old and I purchased some extra insurance for it, like a year or 2 worth when I bought my washer & dryer new. If your washer is less than a year old you can probably get the manufacturer to fix it for free! Good luck!
May 15, 2010 | Frigidaire GLTF1670A Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
