Question about Toshiba Advanced Port Replicator III (PA3314U-1PRP)
Advanced Port Replicator III Plus USB ports stopped working - don't work on any of three different port replicator III, can't seem to find any drivers - any ideas ?
2 Suggested Answers
SOURCE: External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Posted on Jun 29, 2009
VGP-PRS20 port replicator stopped working
I haven't use replicators much but the one on My dell is still working.
I will suggest to remove the laptop(you probably did already) and then insert a USB and see if Windows says anything about it, do the same with the other components. If nothing works then I think the unit is bad or the connector on the back of the laptop is bad.
Of course if you had a similar replicator you can test your laptop and see if its port is bad.
Jun 07, 2014 | Sony VAIO Notebook
Why won't my dell e-port ii replicator charge my latitude e5540?
1. battery is old and can't recharge.
2. Power supply are different, usually two type supported. 3.34/4.62 sometimes it permit to start but don't recharge if battery want exact Voltage.
3. You are using Power Supply for Laptop to E-port, that need 6.7A, so at same it can't recharge correctly your laptop
Jun 05, 2014 | Dell Precision Latitude E-Port Plus Port...
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    Dear Sir/Madam, I have a notebook TM8572T-484G50 which I put into EZ Port IV port replicator to use it as a desktop. However, when I connected the network cable to the port replicator, it doesn't...
    It appears that the ethernet connection from the laptop to the replicator is bad.
    This will likely need to be serviced by a qualified Acer repair facility.
    Your other option (likely cheaper too) is to simply get a USB ethernet connector to use when it's docked.
    Feb 25, 2011 | Acer EasyPort IV LC.D0100.020 Port...
    USB ports do not work with my XP Dell computer
    Did you connect the power to the Port Replicator? The USB may be older in the Targus or the XP Dell. (1.1 older, vs 2.0 newer).
    Sep 16, 2010 | Targus Port Replicator, Docking Station,...
    My laptop is installed in my port replicator; I also have a Dell monitor plugged in to the port replicator. For some reason, after having to re-boot my computer, the output is appearing on my laptop screen...
    Press Fn+F10 to toggle the display back and forth on the laptop screen and external monitor. Pressing the keys a third time would close the display on both displays. Thanks, Abhishek.
    Mar 09, 2010 | Toshiba Advanced Port Replicator III...
    I am now on my 2nd port replicator for lifebook e4010 ... i have 3 fujitsu ac chargers which charge the laptop but not the replicator ??? why ??? pls help ...
    No easy answer to this. The standard port replicators that are used by the e4010 lifebooks seem to be incredibly unreliable. I worked with these laptops for a few years and we were forever replacing the port replicators for users.
    Aug 26, 2009 | Fujitsu Siemens LifeBook E4010 Notebook
    Driver software
    There are a series of HP or Compaq USB drivers (depending on your model) that need to be installed before the dc366b is fully recognized.
    On my Compaq Presario 1500/Evo N1020v I have the following driver service packs installed, You may want to see if these will work with your laptop...
    USB sys drivers & updates
    sp23847
    sp25498
    sp31317
    sp31834
    Port Rep drivers
    SP19198
    sp34083
    May 04, 2009 | HP Advanced Port Replicator 1.2
    Dual monitors: DVI and VGA not supported simultaneously
    It looks like this a problem for the Port replicator III, not II, right? I'm not an expert on port replicators, but if you have even an ok video card, it should work fine even running all three...
    Feb 03, 2009 | Toshiba Advanced Port Replicator III...
    DebitGuy
    Thanks in advance
    Stu
    Jan 08, 2009 | Toshiba Advanced Port Replicator III...
    Toshiba Advanced Port Replicator III (PA3314U-1PRP) Logo
    107 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
