Question about SanDisk Sansa e250 MP3 Player
Sansa is unable to synch new music and only has 5 "bad tracks" on it that I can't delete...
My Sansa 4GB mp3 player cannot synch new music and has 5 tracks that are labeled as "bad tracks" on it that I cannot delete. I'm assuming that these bad tracks are the problem but I can't get rid of them. I tried to reformat the entire player but the tracks still remained. HELP!!!
  • Anonymous Apr 01, 2008
    I also have a couple of bad tracks on mine.. How do you get then off?
  • screw sansa Apr 12, 2008
    When I synch my music the music that is put in the mp3 doesn't work. How do I get them to work ?
    p.s they work perfectly on my computer
  • 8,596 Answers
Two possible methods:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
SOURCE:
I have a Sansa Clip 4GB MP3 Player and I have loaded several playlists onto it. When I try to play one of the playlists it will shift to a different playlist and start playing that. I cannot access my...
Save what you want and Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Apr 08, 2010 | SanDisk Sansa Clip MP3 Player
Can't delete duplicate tracks!
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Apr 17, 2009 | SanDisk Sansa E280 MP3 Player
IM TRYING TO DELETE MUSIC FROM MY MP3 PLAYER
Windows Media Player is the program you will be using to delete files off your Sansa. To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
if (!window.netshel_ord) { netshel_ord=Math.random()*1E16;} if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
BAD TRACK FOR EVERY SONG
The database has been corrupted, click HERE for how to properly format and reload firmware if need be...
Sep 30, 2008 | SanDisk Sansa e250 MP3 Player
Player stopped working with rhapsody
Uh, I had a similar problem which was extremely difficult to solve. What you want to do is reformat your entire MP3 player. YOU WILL LOSE ALL THE MUSIC ON YOUR SANSA. But you can simply resynch it.
http://mp3support.sandisk.com/tools/DeviceRecoverySetup.exe
Aug 23, 2008 | SanDisk Sansa e260 MP3 Player
How can i delete music file from my sansa e250
try formatting the player by selecting format from the properties menu when you right click it in my computer.
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 4Gb Wont let me add or delete songs anymore!
If the PC does not recognize the player, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | SanDisk Sansa e260 MP3 Player
Whas the best way to delete songs off the Sansa 250e? ie. "bad tracks"
The songs are in the wrong format or have expired licenses
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 07, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs.
Isn't it that you just go to my computer and delete it there?
It says to delete it entirely from it.
Jan 08, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
115 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
