Question about Bosch 24 in. SHU53 Built-in Dishwasher
My Bosch diswasher SHU5312UC runs down to one min and won't pump the water in or out.
  • 88 Answers
Hi,theres a overflow swich it the pan under the dishwasher...it might be sticking or your control board behind the disply for 1 min..is bad...call i will fun you through it...
Posted on May 12, 2010
Bosch diswasher model no.She3ar72uc/22! It gives me a code E-24!!! How can I get rid of that code to get my dishwasher to work?
theres either a problem with the drain pump or the re-circ pump is drawing too much current, if the error appears at the start before it fills with water and there is no water left inside the unit it is the re-circ pump, if its not draining water its a blockage or a faulty drain pump
Jan 10, 2017 | Bosch Dishwashers
Bosh diswasher SHE45M02UC/48 doesnt stop when I open the door
That is the drain pump that is running, and it indicates that there is water in the base of the unit. You will need to unplug the dishwasher and pull it out. You can tip it forward to drain the water out of the bottom through the holes in front. Have some towels ready to catch the water. Now if you plug the dishwasher back in, the pump should not run But now comes the hard part - figuring out where the leak is coming from and fixing it. It could be from a hose, the drain pump, or the main pump. Bosch dishwashers are notoriously hard to work on, so I recommend calling in a professional DW repairman.
Feb 25, 2015 | Dishwashers
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
My bosch diswasher is 2 months old and now the water doesn't drain. how can i fix it
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
If the outlet pipe is clear and the pump motor is turning and there is no pump damage then there has to be a blockage somewhere. You could lay the out pipe flat on the ground with the end draining into a tray to see if any water actually does come out. If it does then you do not have a total blockage. This is because it will be most likely draining out of the machine due to gravity and shows that there may be a partial blockage of the pump is defective even though the motor may be running. You will need to remove the pipes to and from the pump to check for blockages and also remove the pump to inspect for damage to the impeller or a blockage in the pump housing where the hoses connect. If the pump housing is clear and the impeller can be turned freely with your fingers then the direct coupled or belt driven linkage between the motor and the pump is the most likely broken and will need repair or replacement. If the impeller cannot be turned easily and does not turn with the motor running then the impeller or the direct linkage is either seized or broken and will need replacing. If your pump and impeller is belt driven then check that the belt is not slipping – this will normally result in increased noise and a possible smell of burning rubber.
Dec 28, 2009 | Bosch Dishwashers
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Diswasher won't pump water out after cycle
it needs a new drain pump for around $65 dollars. the install will take close to $90-$120.
Apr 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Aug 02, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
474 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
