Question about Brother MFC-9440CN Laser Printer
Replace drum, still says replace the drum and now it won't print.
We replaced the drum but the message to replace the drum never went away, and now it won't print. Any suggestions?
  • Brother Master
  • 5,380 Answers
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
Posted on May 12, 2010
  • SG CPA
    SG CPA Mar 04, 2016
    Used remanufactured drum Old printer. Now angry.
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Drum Service Message
Yup reset counter, must open front door and press set button then arrow to replace drum and yes, press set/ok.
Posted on Oct 21, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Replace Drum Soon Message
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
Posted on May 11, 2008
Drum end soon again
My MFC-7420 began to display the message "Drum end soon" so I quickly went out and purchased a new drum. But I decided not to install it until I needed to. Because what does "drum end soon" mean? I thought it would mean that the print quality would deteriorate enough that I would notice the problem. So I continued to replace toner as needed, and pushed the blue cleaning thing down the wire regularly. This went on for over 3 years until *finally* I started having regular print job production problems. I replaced the drum, and the problems were solved. So,my advice is be prepared, but don't replace the drum until you have to -- the message means very little.
Mar 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
Drum end soon brother mfc 7320 printer usb002
My Brother MFC 7420 said drum end soon, so I ordered a new drum. Then I waited for something to go wrong before I replaced it. Basically I was looking for a deterioration in print quality. I waited and waited. I think it was over 3 years. I replaced the toner a few times. While the print quality never really went done, the frequency of other problems finally shot up. When I replaced the drum the problems went away. My advice -- ignore the warning unless you have other problems.
Dec 08, 2013 | Brother MFC 7420 All-In-One Laser Printer
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
Oct 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
Canon imagerunner 2010f wont print
You may need to go into service mode and reset the drum status. Service mode is dangerous and recommended for Canon techs only.
Aug 25, 2008 | Canon imageRUNNER 2010F All-In-One Printer
Error message won't go away.
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 16, 2008 | Brother IntelliFax-2820 Laser Fax
Oct 20, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-9440CN Laser Printer Logo
8,717 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
