Question about Archos TV Plus, 80GB 80 GB Hard Drive
Hi here is my problem, I bought a Archos TV+ last year and it worked fine, but then I moved and I put it away for about 6 months and now I brought it out again and now when I plug it in the light just flashes red and its making a ticking sound, what do I do?
  • rocketbillyr May 12, 2010
    I have an Archos Tv+ and when I plug it in and try to turn it on the light starts to flash red and start to make a ticking sound?
    I tried changing the channel on the remote and it didn't work, now what can I try?
Hi my we achos 7 wont switch on was watching it then it just went of HELP tv
Posted on May 31, 2010
    President:
  • 1,561 Answers
Your device may have been damaged. Try a system recovery to repair or format the disk. For more information about the system recovery.
Before starting a system recovery, first make sure that your Archos is plugged to your TV and is powered.
Restart your device (remove the power adaptor, wait 15 seconds then replug it) and when the red indicator starts blinking, press the TV button on the remote control. Once you are on the recovery mode screen, you will have to select between “Repair Disk” and “Format Disk”.
Start by selecting “Repair Disk” and follow the instructions displayed on the screen.
If repairing the disk did not work, try formatting the disk by selecting “Format Disk”. Note that the formatting will erase all data.
With this, your Archos Tv should start and work fine.
Take care.
Posted on May 12, 2010
  • Sulaimon Jimoh Olayemi May 12, 2010
    Hello, you may try do hard reset on the Archos Tv before you do system recovery, if the reset did not fix the problem then you can now do system recovery.
    Take care.
    I made sure the Archos was plugged into the tv and power was on, I then unplugged the adaptor and waited and replugged it, but I don't get a screen that says anything the screen just stays black and the Archos just keep blinking red and making the tapping sound.
  • 4,924 Answers
The problem is from the power supply ...it is actually an condenser or so ..but try to press on the remote a channel ..and see if it takes it ..this if the sound is made when you turn it from the button ...and do not want to close from the remote but makes the same sound and blinking ..
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your drive is recognized in my computer then note drive lettter and then go to command prompt and type "chkdsk /f:" without "" where f: is drive letter.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa.
I have a archos 402 camcorder and camera had about 2yrs only used handful of times cannot charge was put away in drawer never regwould like to get it fixed was bought on online telly shopping how do i go...
Hello - This problem can happen with any electronic device (especially camera's) that use tantalum capacitors. After a long period of no use they leak and their value changes. Two years in a drawer could well be a problem.
Try the user forum below so you can ask their technical support. My last Panasonic Camera even said in the manual - they recommend charging every 6 months.
Archos user forum for similar feedback http://www.retrevo.com/s/Archos-402-Camcorder-Camcorders-review-manual/id/288ag219/t/1-2/
or http://www.archos.com/support/support_tech/faqs/en/faq_Gmini402.html?country=us&lang=en
Ray
Jan 20, 2011 | Archos Cameras
Some time ago I brought an arcos 604 from new, I put 6 albums on it, then later 4 movies, a couple of months ago I played all my albums no trouble, then last week played two movies no trouble, but now I...
Hi thanks for the e-mail I have scince taken my player to a work shop, so as they can check it out ,
Please can you take my name and problem off of the post it list, and thanks again for your time,
Phil.
Nov 05, 2008 | Archos Computers & Internet
Won't turn on.
Hi My Unit will not turn on,bought last year,water fill icon flashes but no power.
is there a repair depot on Prince Edward Island? Or how do I get it looked after,
unit brought at Sears. Thanks in advance Norm
Oct 02, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Hdd_recovery 2
LAST HOPE !!!
ERROR CODE 102!!!
I JUST FOUND OUT THAT I HAD THAT SAME PROBLEM TOO...AND I WAS ABOUT TO THROW IT AWAY OR GIVE IT TO MY WILD CAT TO PLAY WITH !!! BUT!!! HERE IS WHAT I DID FOR MY LAST HOPE IN SOLVING THIS PROBLEM...
FIRST HERE ARE THE DETAILED PROBLEMS I HAD...
*NO RECOGNITION OF MY ARCHOS IN MY PC...
*ERROR SCREEN..."SYSTEM DAMAGE...REPAIR? NO,REPAIR,FORMAT DISK"
*SELECTED ANY OF THE OPTIONS...SAME STUFF...BACK TO THE SCREEN...NEVER ENDING STORY...
OK...THIS IS WHAT I DID...
1 DOWNLOAD THE LATEST FIRM FROM WWW.ARCHOS.COM...TO YOUR PC !!
2.AFTER DOWNLOADING THE LATEST FIRM UPDATE TO YOUR PC... PLUG IN YOUR ARCHOS TO YOUR COMPUTER...
3 YOU WILL NOTICE THE ARCHOS IS NOT DETECTED AND YOU ARE IN YOUR SCREEN ERROR STILL...OK...TURN YOUR ARCHOS OFF BY CLICKING ON THE POWER BUTTON FOR ABOUT 5 SECONDS OR UNTIL IT TURNS OFF...(NOTHING ON THE SCREEN BUT BLACK...)
4. THEN...WE ARE ABOUT TO TURN IT ON AGAIN...BUT BEFORE THAT... LEAVE ONE FINGER ON YOUR TV/LCD BUTTON PRESSED !!! HERE IS THE SECRET...THEN TURN IT ON !! BUT...DO NOT LET THE TV/LCD BUTTON RELEASED !! IS LIKE YOUR ARE GOING TO PRESS BOTH OF THEM AT THE SAME TIME...AND WAIT FOR FURTHER INSTRUCTIONS...
5. THEN ANOTHER SCREEN WILL APPEAR..SORT OF LIKE...HDD RECOVERY 2...YOU MIGHT WANT TO UNFORTUNATELY FORMAT YOUR DISK...
6. ONCE IT TELLS YOU DONE ! DO NOT PRESS ANY BUTTON... THE PC WOULD NOW RECOGNIZE YOUR ARCHOS...AS A HARD DRIVE..ETC...
7. ONCE IS DETECTED BY YOUR PC...REMEMBER THE FILE YOU DOWNLOAD IT... DRAG IT DOWN TO YOUR ARCHOS..IN THE ROOT SECTION... THAT MEANS...IN NO FOLDERS INSIDE THE ARCHOS...BUT BY ITSELF...JUST LIKE ANY OTHER FILE IN A FLASHDRIVE IF YOU MAY...
8. THEN IT MIGHT ASK YOU AGAIN YOUR PC...YOU WANT TO FORMAT THIS DRIVE...JUST SAY YES....OK...WHATEVER... AND LET IT FORMAT...
9. FINALLY AFTER THE FORMAT SITUATION HAPPENS...YOUR ARCHOS WILL ACCEPT THE FILE...AND IT WILL BE DOWNLOADED AUTOMITICALLY...THEN REOPEN IT TO MAKE SURE IS THERE ALREADY...
10. FOR THE LAST STEP... ENJOY ! MY ARCHOS IS BACK TO NORMAL..IT REBOOT AND EVERYTHING IS FACTORY MADE...HOPE THIS WORK GUYS...AS FOR ME IT DID...
PS. PLEASE BE PATIENT ON THAT OPTION OF THE TV/LCD FOR IT MIGHT NOT WORK RIGHT AWAY...I TRY IT LIKE TWO TIMES BEFORE IT LET ME FORMAT EVERYTHING...BECAUSE YOU MIGHT GET ERROR MESSAGES LIKE..."MEDIA FAILED" ETC... JUST KEEP ON TRYING UNTIL IT ACCEPTS IT.. LET ME KNOW WHAT HAPPENED...
Jul 16, 2008 | Archos 605 WiFi Digital Media Player
Same problem
LAST HOPE !!!
ERROR CODE 102!!!
Jul 06, 2008 | Archos 605 WiFi Digital Media Player
Pen does not work and the LED light on the graphic tablet is constantly blinking
I just fixed the same problem, my tabled was working fine since 3 years, suddently same problem cable. As it is not in warrenty any more, so i opened it and found the usb connecting wires, were some how a) getting short at the tablet entry end, b) the cable was sort of pushing the cabnet out ( on Top left Corner). Initially i brought the ckt bord out of the plastic cabnit, and placed such that the cables are not under any force ( free ) moving, it started working, then, i placed back it in cabnet, with wire properly routet and such that it is not putting any preasure on while i was putting the screws back. and it has been last 1 hour it is working perfectly fine.
Thanks Shree Ammu
Jun 04, 2008 | UC-Logic WP5540U (689076312929)
Archos 504
check the connections again and in settings menu of video recording change the 'input mode' to auto.. if you still cant see the tv output on archos let me know..
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Archos 605 return
erm im sorry but i doubt they will accept it if you have had it for a couple of months. for full confirmation check the warranty information.
sorry
Feb 14, 2008 | Archos 605 WiFi Digital Media Player
Matsui 42" plasma TV
hi everyone, well i,ve solved our problem. i had the same head bashing problem for months,tried everything.what you have to do is turn all display settings to 0 and then run tv for several hours like that,then slowly bring up brightness and colour only leave contrast at 0. i,ve tested this for a week now and bingo the light show is over at last,my god the relief.good luck everyone
Sep 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Archos TV Plus, 80GB 80 GB Hard Drive Logo
316 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Computer Links
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
