Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell 327 wireless router
Starting about a week ago my router dsl light started flashing and sometimes my internet light is is red. i haave been on the phone with verizon wireless several time they told my it was a problem with my dsl filters and the dsl service was fine. so I replaced the filters and I am still having the same issue where i can connect to the internet fora short period then I lose my connection DSl light flashing. verizon has not been very heplful
  • bmoncrief Jul 09, 2008
    I have the same problem. Tried new phone lines and even disconnected the phone. Turned the router off for a minute and still have the same problem. My internet light blinks off and on and one time turned red. The DSL light blinks once and a while, but is usually solid green Cannot contact verizon support a their 800-567-6789 phone number.
  • 20 Answers
When your dsl light in your modem is flashing, that means there is a problem between the connection of your modem to the central office. you're currently having what we call a no sync. the micro filters or dsl filters you mentioned should never be part of the connection of the phone line that connects your modem to the wall jack. the main use of the filters is to clear the dsl frequency and it is only used for the phone lines that you use for your phone. assuming that the filter is between the connection of your walljack to the modem, the dsl light will always be flashing. make sure first that it's not. make sure also that the cables are connected properly from your modem to the wall jack. if the problem persists, and the dsl light is still flashing, the problem is outside of your house and out of your hands and you should call verizon tech support again. they will run the line test and they will get a blue code which will result in verizon sending a dispatch team to fix the problem either at your house or somewhere between your house and the central office. if they still say that they keep getting a passing result in the line test, the problem might be a defective modem already. you can also ask tech support what qualifies as a defective modem because believe me, despite having a modem that has sync and a solid dsl light, i've experienced having a defective modem that is about wireless connectivity and tech support was able to isolate the problem after performing basically all the troubleshooting steps possible. you can avoid having a defective modem by turning it off every now and then to make sure its longevity.
Posted on Dec 20, 2008
I found a solution for this problem. After complaining to Verizon Tech support, I finally got someone to listen. I talked to a Tech that I think was in India, nice lady that walked me through all the line test and finally a modem test. My connection keep dropping through the modem test, which I had a feeling the real problem was. I was told the modem was out of warranty and would cost $59.00 to replace at first, but after calling in so many times this lady sent me a new modem, not a 327W, a 7500. Disconnected the old modem, installed the new one and so far no more dropped connection problem.
Posted on Aug 01, 2008
Can you help to change my mtu # on my westell327w
Posted on Apr 08, 2008
  • 59 Answers
You have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Posted on Mar 29, 2008
Slow internet connection westell e90-610030-06 dsl modem. was pretty fast 2 weeks ago thanks phil
try to do the ff:
power cycle modem/router
check router security settings
check for wifi barriers
delete previous wireless connections
optimize ie
If your wireless connection is working fine 2 wks ago then you may also try to run system restore
Mar 28, 2010 | Westell Wirespeed LiteLine 6110 Modem
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
Red internet light on DSL router Westell 6100
How long have you had your router and how well is it maintained and well vented? Even the most expensive routers need these two things consistently. Failure in doing this may result in a shorter life span than normal. My guess without actually being there is that it's time to try a new one. If you get the same problem with the new router, take it back immediately and call your ISP for service. It could be possible that there is some phone work being done in the area, and you just happen to be a victim!
Mar 10, 2009 | Computers & Internet
I cannot access my wireless network via my westell 327w Modem
the wireless light indicates activity when it is flashing thus it is probably a good sign
A FLASHING DSL LIGHT IS A BAD SIGN
it means activity getting sync which means no internet or anything
Jan 09, 2009 | Westell Wirespeed VersaLink...
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
Jan 28, 2008 | Westell Wirespeed VersaLink...
Itouch with verizon dsl
powercycle the modem and try.
Jan 05, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
1,539 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
