Question about Philips 43P8341 43" Rear Projection Television
Blue Convergence Problems
Ok, thanks to your help, I have successfully changed out the coolant. There are no leaks, so I fired it up with a DVD player hooked up, and I tried to set the convergence as it was all goofed up. The red convergence seemed to work out fine, but the blue convergence has become problematic. When I try to set the single blue convergence, it will only let go left and right, but not up or down. When I go to the multiple blue convergence settings, it won't let me move the blue "crosshairs" at all. Is this an easy fix, or do I need to have it serviced by a technician? Other than that, the new coolant seems to have a real improvement, just the blue convergence is becoming frustrating after all this work. What do you think? Thank you for your time,
Matt
  • Philips Master
  • 8,617 Answers
You will need to replace the conversion IC that controls the blue STK392-110 or STK392-120 however these are so cheap I recommend replacing both as the red wont last much longer. As they usually wear out around the same time. Heres a link where you can buy the replacement ICs and they include step by step instructions on how to install the new ICs.
http://servicemanuals.vstore.ca/
Posted on Mar 29, 2008
How can I get rid of the red and blue outline on my tv?
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 08, 2009 | Philips 55PP9701 55" Rear Projection...
My tv is showing alot of red with blue blotches across the screan
Your TV most likely has fone of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Problem #2 CRT Fluid is Cloudy
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
May 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
JVC 46" projection tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 31, 2009 | JVC AV-48WP74 48" Rear Projection...
Magnavox 51" Model # 51MP392H/17 Color problems
  • Screen looks 3D
Jan 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Convergence Problem
  • Screen looks 3D
Sep 17, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence
the coolant in the blue tube (CRT) needs to be changed thats why youre not able to see a clear blue. You can get the phillips coolant replacement kit at the following link which includes the coolant needed and a steop by step instructions with pictures CD. Heres the link.
Aug 29, 2008 | Philips 50P8341 50" Rear Projection...
Red sideways hourglass
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
Panasonic Rear Projection PT-47WX42CF42
Make sure your yoke plugs are clean and no cold solder joints around them. Let me know? Do you have a scope?
Apr 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Way too BLUE
  • Screen looks 3D
0667c5f.pngSOLUTION
Oct 07, 2007 | Philips 55PP9753 55" Rear Projection...
It turn off itself.
After you replace the ic's how was the convergence? bad or ,almost good if . you had it to do a deep alignmet may you still have problems in the same circuit area.
Jun 29, 2007 | Samsung HC-P4752W 47" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
