Question about Electrolux Vacuums
Electrolux Discovery II 1500c Upright Handle Switch Assembly
Hi, The on/off [off/floor/carpet] switch on my Electrolux Discovery II 1500c became jammed. When I removed the screws from the handle assembly, it slipped and the parts flew apart before I could see the configuration. I need to find a diagram somewhere to ascertain the correct reassembly.
Turns out, the plastic slider/switch cover that shows on the outside of the handle and what physically moves the actual inner switch had a chuck of plastic broken on one side that was hanging it up. Luckily, the piece was right there and krazy glue worked on this particular kind of plastic [bless them].
Now, I'm having problems getting the whole assembly back together so that it will slide. The problem now is that I cannot get the switch, the nylon switch housing, a little H-shaped nylon piece that acts as a spacer/bushing/shim to hold the switch/switch assembly in place within the handle, and the outer switch slider-thing to go back together so that they fit snuggly - I have too much play and the outer switch slider doesn't get a good grasp on the actual switch to move it without the whole thing bobbing.
Is there a known schematic online somewhere that anyone knows of? I just need to see something that shows the proper config. I think I have it together right, but may be missing a piece that flew out of sight.
Thanks!
VacuumRepair
  • 438 Answers
SOURCE: I have a Hoover Slider,
Greetings from GoVacuum,
Please see the link below for a parts schematic to your Hoover Slider, hopefully this will help you put the machine back together. If you find a part that is missing, and would like to order one, just shoot me an email at chris.jones at govacuum.com, and I can give you a price on it.
Please feel free to send me an email should you have any further questions.
Chris Jones
GoVacuum.com
Posted on Sep 29, 2008
SOURCE: electrolux 2100 foot switch
The owners manual is HERE: http://www.aerusonline.com/service/manuals.cfm
But it does not show the inside of the foot/power switch
Posted on Mar 11, 2009
SmartAlec
  • 171 Answers
SOURCE: Broken Switch on Hoover Windtunnel U6474-900
Hi there SmartAlec from NelsonVacuums.com.au here. I have a U6445 but i suspect there is little difference. Mine has only 2 screws as well and it also was very stiff. After a bit of medium pressure and a twist side to side mine came off.
Posted on Aug 31, 2009
Dysonteam
  • 167 Answers
SOURCE: Placing the handle of my Dyson DC07 into its
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
  • 500 Answers
SOURCE: I opened the bottom to replace the brush (which
Hi sdibowitz,
I do not know if this will help, but here is a exploded view of your vacuum cleaner.
LINK
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Sep 09, 2011
How do you start an electrolux floor pro
With the shampooer plugged in the receptacle and in an upright position with the handle up, step on the handle release with your left foot at the bottom left of the unit. It will release the handle back and also triggers the "on" switch at the same time. voila!
Hope it helps! amerivac4u@yahoo.com
Jun 07, 2014 | Electrolux Floor Pro Vacuum
My upright electrolux persicion vacuum when turned on just makes a horrible sound both on bare floor and on carpet brush does not turn
Hi, sounds like you need a new belt or brush and bearings . Sometimes when a belt goes it makes a bad noise as one of the belt teeth make be worn out. Hope this helps.
Jan 22, 2014 | Electrolux Vacuums
Troubleshooting
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Apr 07, 2011 | Electrolux Vacuums
I have an Electrolux Epci 3500 Sr upright vacuum cleaner ... 100 percent positive switch is shot and one of the wires inside is fried but before buying a new handle assembly online how do I check the...
The switch is replaceable, so you don't need to replace the complete handle assembly. I've got a 3500 that I replaced the switch on and it works great now. You can get a new switch at the local Aerus Electrolux store. To find the nearest store, just follow the directions on the below site.
I do recommend letting the service tech do the replacement.
http://www.aerushome.com/storelocator/
Nov 26, 2010 | Electrolux Epic 3500 Vacuum
Brush will not spin
Hello :
Try this: switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
PLEASE RATE !
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Kind regards
Darran
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I fix the carpet/floor switch on a hoover windtunnel bagged self propelled
The carpet / floor switch is a mechanical assembly. the bottom cover needs to be removed to expose the screws for the hood cover to be removed. then the switch can be accessed for repair
Oct 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
591 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
