Question about Nokia 6280 Cellular Phone
6288 switch on button not working
Few days ago my down navigation key stop responding,but after i do the master turns out to be ok. But then i notice that my switch on button stop working.i master reset my phone again,nothing happen this time.
To make it worse,yesterday my phone was stuck in msg inbox,then i took out the battery to restart it since the switch on button not working.Now, i can't turn it back on. help me!!!!!
  • 1,944 Answers
You should try to reflash your phone's firmware.
Posted on Mar 29, 2008
I did not open my game on my Phone V3 If i open then came a massage "No Installed MIDLet Suites" Please solve my problem
  • 1 Press the V3's "Menu/OK" button, located in the center of the directional keypad.
  • 2 Use the arrow keys on the directional keypad to navigate the menu down to the "Settings" option, then press the "Menu/OK" button.
  • 3 Select the "Initial Setup" option in the Settings menu and then select the "Master Reset" option in the Initial Setup menu.
  • 4 Enter "000000" into the field in the Master Reset menu; if you've changed your L9 security code, enter the new code instead. Press the "Menu/OK" button.
  • Dec 27, 2010 | Cell Phones
    With article and troubleshooting guide solution for Android Hard reset way
    • Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
    1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
    Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
    2. Power the phone off all the way, press and hold the Volume Down key and press then release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
    Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
    3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
    Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
    If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
    Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
    4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
    From the Android Recovery screen, press the Search key.
    Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
    Select Yes - delete all user data, and then select OK (again lower left).
    Select "reboot system now" and press OK.
    5. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
    While the phones power is off, press and hold the volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
    A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
    Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
    Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
    After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
    Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
    6. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
    Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
    The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
    Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
    Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
    After it's done make sure "reboot system now" is highlighted and then tap the Power button.
    In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
    7. Here is a hard reset for a Sharp Android Smartphone.
    While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
    Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
    Scroll down to Yes - delete all user data and then press the Power key to confirm.
    Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
    8. Here is a common method used to hard reset an LG Android smartphone. So if you need to hard reset an LG Optimus this is the hard reset key combination to try first.
    After the LG phone has been powered off, press and hold the Volume Down button. While holding the Volume Down button, press and hold the Home button. While holding both the Volume Down button and Home button, press and hold the Power button.
    Continue holding these three keys down simultaneously until the LG logo appears.
    Once the LG Logo appears release all of the keys. This will complete the reset on many LG phones; you will be given the option to "Select your language" and can proceed with setting up your device as if you were setting up the phone for the first time.
    If however, you are taken to a fastboot screen or a screen with additional options then use the Volume Down key to scroll to and highlight the wipe data/factory reset option and then press the Menu key to make the selection.
    The phone might give you a confirmation screen in which you can use the Volume Down key to scroll to and highlight Yes -- delete all user data and then press the Menu key to make the selection.
    If you get an option to reboot system now then select that option with the Menu key. The phone will reboot, which can take a couple of minutes, and the hard reset will be complete.
    Now you know how to hard reset an Android Smartphone and the next time your touch screen stops responding, your phone freezes, your phones power cycling, you forget your password, or pretty much any reason you wouldn't be able to perform a reset through the settings, you'll be set.
    If I have forgotten any key combos that you know of, leave the method in the comments below so that I can add it to the list. Don't forget to check out some of our many other popular posts and don't forget to power your phone off every couple of days and watch what applications you choose to download onto your device that way you can keep your phone healthy and efficient. Hope you enjoyed the article, have a fantastic day, and enjoy your phone.
    Thanks for checking out this Solution. contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas
    on Jun 24, 2015 | Cell Phones
    My phone buttons are not working
    Hard Reset:
    Either through the menus or:
    1. Turn the Moto Q off
    2. Hold down the power button (hang up button) and the center key button (the button between the arrows) at the same time.
    3. When the verizon logo appears on the device. Let go of both buttons.
    4. A screen will come up saying to do a Master Reset. You will hit the left soft key to say yes to confirm.
    Your Moto Q is now been hard reset ( Master Reset ) without having to go through the menu of the device.
    There's currently no other way to reset your phone without using the buttons so.
    If you are having problems with your Q already (since they were just released a few weeks ago), don't be afraid to exchange it for a new one.
    The Motorola Q tech support line that I called was 1-800-657-7576.
    Aug 23, 2010 | Motorola Mobility Moto Q
    My C120 will not shut down using the red power off button
    When you turn on the breaker switch push the nearest grey button to the powerbutton than you get a factoryrest your software shoud be 4.29
    Jun 29, 2009 | Raymarine C120 System Pack C120 Raystar...
    Switch on button not responding
    Hi your problem will be with a stuck key this not allowing other buttons to work the only way to solve this problem is to remove the outer casing and clean the pads behind the buttons it might have evn got damp and coroded as this causes the problems your describing.
    The big problem is taking the phone apart as its not east to do and it also needs to be undone in certain order else you can warp the board destroying the phone completely and when putting back to gether it has to be done in certain order and the screws have to be tighten up to certain tension else the board will also warp.
    If you are unsure of what you are doing then dont do it as you can destroy the phone beyond repair ok
    You can try searching online for instructions on how to remove the cases but these are hard to come buy but would be of help to you.
    Of unsure take it to phone shop as it wont cost to much to get repaired and it would save you destroying the phone beyond repair
    Its not just the screws that need undoing their are also clips running along edge of the case and as its a slide phone their is a spring between the two halves that need removing before the ases can come off but this spring can destroy the ribbon betweent the two halves so be warned ok
    Mar 29, 2008 | Nokia 6280 Cellular Phone
    well dirt under key pad or water ect would need t4 t5 star tools take it apart clean it well ok thx nick
    Feb 06, 2008 | Motorola Mobility RAZR V3
    6288 Turning On Problem
    Try a reset:
    First turn it OFF, take the SIM card out.
    Press * 3 send at the same time and turn phone on. Keep them pressed until the reset screen appears.
    Give it time to reset.
    Jan 11, 2008 | Nokia 6288 Cellular Phone
    Dial key and up arrow not responding
    send the phone to three and they will either replace it or send a new but make sure to write a letter explaining what the problems are and they sahould sort it.
    Jan 10, 2008 | Nokia 6288 Cellular Phone
    Switch on key stopped working and Nokia Sw Update dont recognize it anymore
    Try a software reset, just make sure your contacts are backed-up first. It could either be *#7780# Restore factory settings or *7370#
    Nov 29, 2007 | Nokia 6288 Cellular Phone
    Nokia 6288 stop working
    software problem,you need to update it,i get many of these every day
    Sep 02, 2007 | Nokia 6288 Cellular Phone
    Nokia 6280 Cellular Phone Logo
    129 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
