Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
My tv is not doing the correct magic focus adjustment
My tv has the picture with double image
  • 1,476 Answers
You have bad convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 12, 2010
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    Need to adjust lens focus on all three projectors
    If its a double image that sounds like convergence.
    Apr 09, 2009 | RCA D52W23 52" HDTV CRT TV
    PT4298HD Double image
    BINGO thats exactly what i get paid to do same price 285.00
    Nov 30, 2008 | Akai PT4298HD Rear Projection Television
    Hitachi Mo# 53uwx10ba double image
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
    When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
    You can get more information and a DIY convergenece repair kit with instructions from the link below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms...
    *Screen Looks 3-D
    *Colors wont align
    *Screen may look distorted or warped
    *No Audio/Video - TV Shuts down - May also make a constant chirping sound
    Problem #2 - Another common problem is dull or washed out video.
    Your set may have one or more of the following symptoms....
    *Dull looking picture
    *White looking picture
    *Halos around objects
    *Red/Orange looking picture
    bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
    Double image on green
    Focus won't help if it is a double image. Sounds like convergence amps need to be replaced. Very typical on these.
    Jul 04, 2008 | Hitachi 61SDX01B 61" Rear Projection...
    Magic Focus does not work.
    Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
    with upgrade Stk394-160E Hitachi part # CZ 01341,change both
    for reliability.....check B+ feed resistors for over-heating....T.
    Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
    Blurred picture
    try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
    Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    Hitachi 43FDXO1B Convergence?
    Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
    1. Receive an NTSC signal.
    2. Press Magic Focus to begin magic focus
    3. Press magic focus again during the magic focus process to get the “stop” screen.
    4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
    5. When you first get in here? I believe red is the selected color by default (it is flashing).
    6. To choose other colors to converge, use the following buttons on the R/C:
    · “STATUS” - Green
    · “0” - Red
    · “ANT” – Blue
    7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
    may want to go back and adjust some red again? etc. until the convergence looks good.
    · Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
    · Use thumb stick to move the convergence point color.
    Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
    3x3 – ‘coarse’
    7x5 – ‘medium’
    13x9 – ‘fine’
    10) To get to each of these patterns use the following on the R/C: (only if you need to)
    1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
    2. (7x5) Press “0” 5 times
    3. (13x9) Press “ANT” 5 times
    11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
    12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
    13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
    14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
    15) Green dots will be displayed when operation is completed.
    16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
    17) Turn power OFF.
    18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
    Jan 13, 2008 | Hitachi 43FDX01B TV
    It needsre- align the projection bulbs to get rid of the double image
    More than adjustment...needs convergence circuit IC's replaced.
    STK392-110 subs to upgrade STK394-160E Hitachi CZ 01341..
    then use magic focus........................................T.
    Dec 17, 2007 | Hitachi 43UWX10B 43" Rear Projection...
    Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
    291 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
