Question about GE GSH22JFR Side by Side Refrigerator
We have a GE TFX20JR refrigerator. The doors are uneven.
We have a GE TFX20JR refrigerator. The side by side doors are uneven. How do I adjust them?
  • 29 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
SOURCE: fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Posted on Nov 15, 2008
  • 4 Answers
SOURCE: GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Posted on Jan 01, 2009
SOURCE: freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Posted on Dec 16, 2009
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
My side by side GE Profile refrigerator has uneven doors. Can they be leveled? The top piece of plastic hits the plastic on the top of the door
yes you should be able to adjust the door at the base of the door at the hinge with a 3/8" open end wrench
Apr 27, 2012 | GE Refrigerators
ICE MAKER QUIT WORKING ON GE 19.7 TFX20JR BUT WATER STILLS WORKS
you have a dual valve one side quit working. get a new inlet valve.
Aug 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Side-By-Side Refrigerator Model # TFX20JR . The refrigerator handle is loose and needs tightened and I can't find anything in my manual telling me how to do it. Your help would be greatly...
you must remove the inner panel to get to the handle screws on most ge 's . use red lock tight on threads to prevent it from doing it again . mm
Aug 09, 2010 | GE Refrigerators
Door Height adjustment. Side by side doors are uneven. GE Refrigerator. And no I don't want to replace the hinge.
as the doors are set at the factory,the easiest way is to put spacers under the feet, to square up the unit.... that is, if you dont have adjustable feet fitted.....
Aug 02, 2010 | Refrigerators
GE TFX20JR
how is the freezer? if it is ok is the freezer back panel full of frost if so then you have a defrost problem and the ge is really good for the heating elements to go bad
Jun 26, 2009 | GE GSH22JFR Side by Side Refrigerator
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
57 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
