Question about ViewSonic VX924 19" LCD Monitor
Monitor problem did you ever find out what was wrong with your monitor? I think I'm having the same thing with mine. Just went out while I was on it yesterday, and at first i thought it might have overheated. So i let it cool, but everytime i turn the power on it, will just blink, power on, power off, power on, power off, fairly rapidly. Anyway, just checking to see if you found any solutions
  • 558 Answers
The most common solution is that the board inside has blown capacitors. replace these ad you should be ok.
Posted on Jul 31, 2008
No Signal
Check your monitor. Mine did this and is an ACER. Make sure the cable in the back of the monitor didn't wiggle out. (Mine did.) Another thing to try is plug it in to SD if you're using HDMI. My HDMI port went out a while back so I had to use SD.
Dec 07, 2011 | Acer Aspire m5640 PC Desktop
I just had had it repaired before it went wrong again... so I dont want bring it to a repairman again... I think if It was a minor error only it wouldnt have gone wrong after being repaired for the second...
Can you be more specific about "went wrong"?
Are you looking for repair help or are you just venting?
These are wonderful but complicated monitors.
I have sucessfully repaired many.
Monitor Mike
Jan 10, 2011 | ViewSonic VP2030b 20.1" LCD Monitor
Screen went black,then said it was in power saver mode. Tower is on but nothing appears on monitor. what are the possible problems please. PSU or Hard drive?
Try hitting the power button on the monitor.... If that doesn't work make sure the i think "VGA" is connected... The cable with the blue thing on the end... make sure it is properly secured... in there.... There is nothing wrong with the hard drive.....
Jan 08, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I bought a used KDS 17" color monitor, Rad-7,
I agree that the overheat was the supply being too small. Not only the voltage rating is wrong, but I'd bet the amperage is alsotoo low for correct operation. Check this link. I have bought power bricks from them for laptops, monitors, and power tools - all good quality without breaking the bank. They ship pretty quickly as well. http://generalsaving.com/productfile/G_LCD12V3A/1000/G_LCD12V3A_z_0157.php
Jun 08, 2017 | KDS Radius RAD-7 17" Flat Panel LCD...
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
Dead monitor,,,,,,,,,,,,,,,,,,,lcd viewsonic
If the power supply is not wqrking then it is the invertor unit that has dies.
Replace the monitor is the best advice- If it that recent out of warranty may be worth contacting 'viewsonic to see if they will discount you one.
Jul 19, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
OOPS! How to invert screen image )get it back where it belongs)
just take it to the showroom where u got it from. this problem can be fixed without any big problems
Feb 20, 2008 | Samsung SyncMaster 912N 19" Flat Panel LCD...
LCD Monitors x7g troubleshooting
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Jan 05, 2008 | Sceptre 17" LCD Monitor
Monitor not working...sorta
I just changed my video card and after turning up my screen refresh rate (Hz) my monitor started doing the same thing. Monitor worked great for a long time but now its done! The only thing I can think of is that it has to have 60Hz, turn it up for gaming and its too sensitive to frequency. By the way, mine will turn on after a few power cycles.
Dec 01, 2007 | Mag Innovision LT776s 17" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
44 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
