Question about Panasonic KX-TA308 Phone
Use only for intercom that is why we need to block the out going
  • Panasonic Master
  • 2,460 Answers
There are a couple of things that make this a difficult answer. First of all, Panasonic made 2 different TA-308's, one for the U.S. market and one for the rest of the world. The U.S. 308 is non-expandable.
Pretty much, the TA-s have a similar program, so this specifically applies to the U.S. version, but it should also work for the other. This also assumes that you know how to get into system programming and are familiar with the 3 digit programming of a Panasonic system.
Do you need to allow for emergency dialing? In some areas, you cannot block it. If you don't have to worry about 911, then you can restrict access to outside lines by programming 405-407 for no line access. If you have to allow for 911 or other emergency numbers, then you have to use Toll Restriction and Class of Service.
Programs 601-603 set the COS and the manual has TRS examples, but it basically means you set the COS to something other than 1, like 5, then go into 305 and put all digits into the denied digits (using PAUSE as the wildcard). 911 will override by 309's emergency dial number set.
In passing, program 306 lets you store 80 exception codes to COS restrictions.
Carl
Posted on May 12, 2010
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
M&s intercom model 200 manual
Here is a link for the manual.
NuTone NM200 4 Room Intercom Kit NM200 4 Room Intercom Kit
Please visit our website if you need a replacement part or if you have more questions.
Central Vacuum Intercom and Whole House Audio Systems
Don't forget to like and visit our Facebook page
https://www.facebook.com/QualityHomeSystems/?ref=hl
Aug 16, 2014 | Radio Communications
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Oct 05, 2010 | Lucent PARTNER18 Corded Phone
Meridian M7310 intercom key not working on anyphone
Do Feature **CONFIG, go to CONFIGURATION, select the second option, should say Line something, keep scrolling and it will say I/C: #,. press change, you can have a max of 2 Intercom keys, if you need other info, go to youtube.com and search for "thenortelguy"
Aug 28, 2009 | NorStar Meridian M7310 Phone
CANT GET INTERCOM TO WORK
Be sure you are pressing the correct extension key for the phone you are attempting to call. Just press 'intercom' and the key number (from the right side of the phone marked 1-16).
Feb 18, 2009 | RCA 25414RE3 Corded Phone
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
May 22, 2008 | Dual Handset Cordless Telephone with...
Blocked Intercom
If you do not have a button to press to call him, you must press the intercom btn and dial his intercom # . to find his intercom # , go to his phone and dial feature 00. His intercom # will be displayed. press feature 00 to exit.
Mar 06, 2008 | Lands Phones
Partner 18D intercom not working
If you mean intercom, as in Speaker/overhead paging, then the buttons need to be reprogrammed to access the intercom. If you mean calling from one avaya phone to another, then the system is more then likely fried. from your system press the intercom button, 61. that should give you the paging access that I think you are looking for.
May 21, 2007 | Avaya Corded Phone avaparp18d
Panasonic KX-TA308 Phone Logo
100 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
