Question about Nike Watches
Nike Triax Metal Linear Regular. Hi, I am trying to reset
Nike Triax Metal Linear. Hi, I am trying to reset this watch for a friend - he has lost the manual. He has had the battery replaced and now there is nothing except black lines across the face of the watch. Many thanks, Elaine
SOURCE: nike triax speed WR0082 regular
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
Posted on Feb 17, 2008
  • 29 Answers
SOURCE: how to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Posted on Mar 11, 2008
SOURCE: nike heart rate monitor triax c5
I was able to view the instructions here: (no title)
http://www.klokker24.no/ressurser/1183.pdf
Posted on Dec 27, 2008
escapement
  • 2334 Answers
SOURCE: I need a wristband for my watch nike triax
NIKE contact address: USA 888-350-6453, Nike Timing Service Center, 7501 N.Harker Dr., Pearia, IL 61615, www.nikewatchrepair.com
Posted on Mar 28, 2010
SOURCE: turn off hourly beep on nike triax fury
Press the Start/Lap button in Time mode to turn on/off. This also turns on/off the beeping sound when switching between the different modes.
Posted on Jul 27, 2010
Nike triax
Tissot 1853 I don't know how to reset the time after I changed battery.Pleas held me
Oct 05, 2013 | Watches
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Somehow I managed to reset my Nike triax 50 by pressing the watch up against a metal bar when trying to strap myself in on an amusement ride. I've tried setting the time and even switching modes but...
mcdevito75 here, It"s possible that when the watch got pressed up against that bar and your arm you mis--aligned the buttons (inside the watch) used on the watch to reset it. BEST BET, Visit a small watch repair shop in your area and have them take a look at the watch, or, you can use the repair service directory right here ay fixya, bottom of this page, click on repair service directory then watches.
Jun 27, 2010 | Nike Triax 50 WR0083-029
How to change the time display
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Mar 31, 2010 | Nike Triax CV10 Wrist Watch
I have a Nike Triax 35 and just had the battery replaced. Now there is no sound when the alarm goes off. The sound icon flashes but I can't hear anything. How do i get the sound back?
were did you get your battery replace at. becuse when you take the watch apart there is a little spring that makes contact to the bottom of the case back to a metal thing that is glued to the case back. Witch is the speeker for sound. If they lost this spring no sound. :(
Jul 13, 2009 | Nike Triax C-3 Wrist Watch
Nike heart rate monitor triax c5
Nov 17, 2008 | Nike Triax C5 Wrist Watch
Nike Triax Backlight
Usually after changing the battery you need to "ac" it, which means to restart the ic, or else the light will keep on. please check there is a area on the pc board says "AC". all you need to do is use a metal pin to contact it. if it dosn't work then try press all push buttom at same time, it has the same function as press "AC"
Tsai
Jan 27, 2008 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Watches Logo
473 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Nike Watch Expert? Answer questions, earn points and help others
