Question about Dell 5650 Computer Speakers
Keeps blowing fuses
Works, but possible short in fuse box or fuse plug.
    Sergeant:
    Champion:
  • 236 Answers
Operate or dissapate
look for the short or buy a new one
Posted on May 12, 2010
Cigarette lighter fuse in 2003 dodge neon keeps blowing
The cigar lighter is shorted to ground and needs to be replaced.
Apr 15, 2014 | 2005 Dodge Neon
I have a 97 galant that keeps blowing the 100 amp fuse? alternator tested good twice checked wiring reads good is there another fuse ?
Usually that fuse powers the alternator and the fuse box.
It would have to be a big short to ground to blow that fuse.
Its possible the main wire to the alternator is touching a metal spot, or the alternator is shorting out inside when it is running.
What is draining the battery may be something else, or the battery could be discharging after the fuse blows if the alternator is not charging it.
Apr 15, 2013 | 1997 Mitsubishi Galant
94 Jeep Grand Cherokee 4x4 with the 4.0 Keeps blowing the fuse that controls the fuse box inside the jeep, its blowing a 40 amp fuse. I believe there is a short. but i don't where to look.
Get yourself a set of factory wiring diagrams,
otherwise your wasting your time
You have no idea what you working on, without
reference material
Helm.Com
Jun 20, 2012 | 1994 Jeep Grand Cherokee
Hi I have a 1990 db7 the problem I have is it keeps blowing the electric winow fuse.If i change the fuse it works a couple times then blows,everything else is fine, any ideas? Mike
If it is constantly blowing fuses it is possibly a short circuit. The short may be in the motor causing it to draw to much current and blowing the fuse. Needs to be checked with an amp meter.
Jan 19, 2011 | 1998 Aston Martin DB7
My lumina starts but only stays running for a minute or so before it cuts off and 1 of the fuses keeps blowing under the hood the cover for the fuse box is missing so i dont know what fuse it is
I sounds like it may be your fuel pump fuse or relay blowing, if this happens to be the case, I would go to your local salvage yard and obtain a fuse box cover to see what fuse is blowing, if it is the fuel pump fuse you have a short in the wiring or the pump causing an overdraw of amperage blowing the fuse, you will have to find where the short is, it could be the pump itself or a bare wire going from the fuse box to the pump, if its an ignition fuse you could have a bad coil or igition module that has an internal short, i would first find a cover to see what fuse actually keeps blowing before you can start a better diagnosis of whats going on.....
Dec 11, 2010 | 1995 Chevrolet Lumina
Fuel pump fuse keeps blowing?The fuse is by the right front of radiator.
FUEL PUMP WIRES HAS A SHORT OR FUEL PUMP BAD SHORTING OUT.BLOWING FUSE.CHECK FOR SHORT AT FUSE BOX AND AT THE FUEL PUMP WIRES.THE PCM GOES BAD SOMETIMES IT WILL SHORT OUT BLOW FUSE TO FUEL PUMP.
Apr 14, 2010 | 1992 Oldsmobile Cutlass Ciera
EEC relay fuse keeps blowing id put a new fuse in the truck it would run for about 10 seconds then blow the fuse again.
There are 3 relays mounted below the fuse box .
The green I believe is fuel pump relay and the brown is EEC. The third relay is for the A/C WOT.
It is possible the wiring is shorted, check there, it is also possible you have a bad fuel pump.
Please let me know what you find.
Feb 07, 2010 | 1991 Ford Explorer
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Fuse Keeps Blowing
Replace the lighter assembly, it is shorted, this is very common.
Nov 26, 2008 | 1991 Lexus LS 400
Dell 5650 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
