Question about Gateway 507GR PC Desktop
Computer/Motherboard Issues In the last couple of months, we have had a circuit breaker blow in our living room when we plug in and turn on our vaccuum. Although our computer is plugged into a surge protector on the same circuit, we have since experienced different problems with the computer itself. First time the circuit breaker blew, our power supply went out on the computer. We have since replaced it. Since the second time the circuit breaker blew, we had more major problems with the computer. We were recently told our motherboard needed to be replaced. Now our computer was working fine before all this started with the blown circuit breakers in our home. What I am wondering is, would the circuit breaker blowing out be the reason our motherboard is damaged on our computer?
    Sergeant:
    Champion:
  • 236 Answers
Buy a circuit protector for just ur computer and call a electrition
Posted on May 12, 2010
I have a 78 holiday rambler imperal limited, I have no outlet power in bedroom, bathroom and two plugs in living room one plug in living room does work. All my fues are new????
It could be a couple of things.
1.Buy a plug tester from Home depot or Lowe's start from the one that works and move over to the ones that don't work. The Plug tester will tell you what wire is lose. Most of the time its just wire nut. BEFORE WORKING ON WIRES MAKE SURE YOU TURN OFF POWER AND UNPLUG BATTERYS. Power must been on to use plug tester.
2. lose wire it could be the neutral", from the power inverter
Or in one of the j-boxes of the plugs.
If this doesn't work let me know.
Oct 02, 2015 | Electrical Supplies
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
LAst night we lost two rooms completely light and outlets. we try the reset the breaker nothing would come on. This morning we unplug everything turned on the breaker, and plug everything back in...
1) A circuit breaker will not reset if breaker is hot, or if there is a short to ground.
2) Hot breaker: If circuit is pulling more amps than the breaker rating, or if breaker is loose on the busbar, then breaker gets hot, and trips.
3) Volts x amps = watts. Add up wattage of everything on breaker and divide by 120Volts and that gives you amps.
If your breaker is 15 amps, the SAFE maximum is 80% or 12 amps.
4) If breaker is loose, you can smell burning and hear crackling sound. Jiggle the breaker around and listen for crackling.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
5) If there was a short somewhere on the breaker circuit, the breaker will trip.
When you unpluged each device and then the breaker was reset, then that says problem is probably NOT the wiring or breaker.
The problem was probably inside one of the devices that was plugged in.
6) If breaker trips again, unplug each device one at a time, and then try to reset breaker after each unplug to see if you can isolate suspected device.
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 29, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
Turn air conditioner on, after a couple of minutes circuit breaker for room shuts off. a/c is 2 seasons old, digital ge, 12000 btu???
you have to much stuff on one circuit. turn everything off on the circuit that is blowing then try to run the ac.
May 29, 2010 | GE AJCQ08ACB Air Conditioner
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Blowing circuit breaker
If you live in Rancho Cordova, CA and need appliance repair service call us at 916 823 3070 or visit our website Rancho Cordova Appliance Repair 916 823 3070 Rancho Cordova CA
Sep 02, 2017 | Cadco OV-250 Electric Single Oven
Gateway 507GR PC Desktop Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
