Question about Whirlpool AWM8143 Front Load Washer
W/pool awm8143 not finishing cycle fault F06 flashing on display
My machine is cutting out around the wash end-rinse start. I have watched it and machine tends to start some sort of spin during wash or rinse then conks out, flashes F06. It is almost like the load is out of balance, it tries to correct it, can't, so gives up. I've never had out of balance issues before. My machine is 4 years old. Sometimes I have re-set to just rinse/drain option and that haS completed the wash for me. Now it just conks out in all the cycles, once it has done it already. Occasionally I will get a clean run with no issues. I have checked and cleaned the filter on numerous occasions.
Thx
    Problem Solver:
  • 6 Answers
I had this same problem, an intermittent F06 fault.  The F06 code means a tachometer fault.  After some fault-finding, I did manage to fix it.  If this error code happens to you and you know a bit about electronics, try taking apart the timer and looking for dry joints between the main board and the perpendicularly-mounted microprocessor board. Over time vibration can cause the soldered joints between the two boards to crack and fail intermittently. 10 minutes to disassemble plus 2 minutes with a soldering iron could save you a $400 repair bill.
The service manual is available for download on the web if you google hard enough.  If you have a CRO available, the tacho waveform should be a nicely-formed sine wave with a frequency proportional to the RPM.
Posted on Jul 16, 2008
SOURCE:
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Awm8143 F06 problem
:-) Actually that was one of the other symptoms of the F06 problem; our machine started banging and walking all over the laundry, which it never did before.  After I fixed the timer, it never did it again.  All I can figure is that when the timer was getting erratic information from the tacho, it would spin the drum too hard or something while it was waiting for the tacho to give a signal.
Troubleshooting the problem was a real pain in the **** because each time I took the washer apart to test it, the problem seemed to magically go away.  Sometimes it would do a whole cycle without any problems, and sometimes it would F06 six times in a row.  In the end that was one of the clues that helped me figure out it was a cracked solder joint.
Anyway good luck with the yours.  Thanks for the tip about FA F9, I'll remember that one...
Jul 19, 2008 | Whirlpool AWM8143 Front Load Washer
AWM8143
FA is the emergency shutoff switch that detects when water is pooling underneath the machine -> a leak.
"Check float switch under machine, empty any water from catchment tray, check for water leaks or oversudsing".
Jul 10, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 sixth sense
Try replacing the brushes this may solve the problem
Jul 03, 2008 | Whirlpool AWM8143 Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
592 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
