Question about Sharp AR-M355N Copier
Finisher is not working trying to disconnect from copier cannot find cord
  • Sharp Expert
  • 1,326 Answers
There is not a cable to unplug. The finisher is part of the copier. It is not a easy task to remove it.... Why don't you just turn that off as a option in the user mode.....
Posted on May 13, 2010
  • Ron Abisi Jul 25, 2012
    How do you turn off the finisher?
KM-5050 Finisher not attaching, Why?
Make sure the connector cable from the finisher is plugged into the copier. Unplug the copier power cord first if you have to reconnect it.
Jul 13, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
How do i disconnect finisher from canon c5045
in the front side, between the finisher and the copier you will see a lever, just pull it up and release the finisher
Apr 24, 2014 | Canon Office Equipment & Supplies
Kyocera KM-2530 printer displays "Attach Finisher." It was working until we moved it recently. Checked all cords and rebooted several times to no avail. Couldn't see any push rods or buttons that need...
on the copier metal bracket that finisher attaches far end or front ull see a metal pin that sticks out.
That pin goes in to the finisher white plastic hole.Inside that hole there is a switch that tells the copier the finisher is attached.
Oct 07, 2010 | Kyocera RI-3530 Black and White Copier
My refilled cartridge doesn't seem to be recognised by my printer. Do these printers not accept refills?
To let the printer recognized the refilled ink you must do the reset procedure to clear the error. Here's how to do it.
1. Disconnect power cord from the back of the printer.
2. Press and hold down Power button while plugging the cord back in.
3. While holding the Power button, press the Reset button twice
(The printer will display "Factory 1". Allow the printer to finish reading until the word "idle" appears, it will take sometime)
4. Disconnect the power cord.
5. Reconnect the power cord
6. Turn the printer on
If errors still persist, this one for finale.
1. Press and hold the Reset button.
2. Release the Reset button when the printer restart by itself.
Let me know if this procedure help you.
Please comeback and do rate this solution.
Thanks for using Fixya.
Aug 25, 2010 | Canon MP610 Photo All-In-One Printer
Error 0000500-0000. Finisher error. Ran through disconnecting finisher, turn on copier to cycle, turn off copier, reconnect finisher and turning on again. No fix. Any other way to clear code? (Went into...
sounds like the DC controller and or the Finisher controller have gone bad. Unfortunatly there is no easy fix for this problem. you will need to get someone out to have them checked but if you leave the finisher off of the copier it should still work so at least you can make the copies.
Jun 11, 2010 | Canon imageRUNNER 6000 Copier
I need the reset finisher code for ar507
If finisher works no need for reset.disconnect finisher cord and use it
Apr 09, 2010 | Sharp AR-507 Copier
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
E000540-0001
0001 - The paper surface sensor remains unchanged 10 sec after the tray ascent/descent motor is driven.
It sounds like you have a finisher attached to the machine, You will need a tech to come out and replace the sensor, buy you can still use the machine by doing the following.
>Turn the copier off.
>Unplug the finisher (cord in the back)
>Turn the copier back on.
The copier will still work, but will not recognize the finisher, and because the error is in the finisher the error will be gone.
Oct 16, 2009 | Canon imageRUNNER 6020I Copier
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Sharp AR-M355N Copier Logo
101 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
