Question about Sharp FO-4400 Fax
We keep getting paper jam after paper jam (at least 7x's now) The jams seem to be toward the bottom where we take the paper drawer out. We do push the green release button and pull out the paper. We have checked the other areas and do not see any tiny pieces of paper that may be causing the issue. I do notice that when we pull the jammed piece of paper from the bottom I see slight ink marks on the paper where maybe rollers were. Any suggestions?
  • 59 Answers
Hi did u have cheq all the paper path sensors may be any one of them stucked or may be if you have old machine may you have clean whole paper path sensors thanks
Posted on May 12, 2010
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
My HP K550 officejet printer has recently been having some unusual jams in that it feeds a sheet of paper halfway through the printer w/o printing, then the green and yellow lights flash like a paper jam...
it seems that you are correct
Push the button on either side of the rear access panel or the duplex unit and remove the panel or unit.
Check inside the printer to make sure that the cam drawer is in the correct position, toward the front. If the cam drawer is not forward, pull the cam drawer into the correct position.
With all of the paper trays removed, check to ensure that the pick-up roller is up, not protruding down towards the tray, and no media is stuck to the roller.
Remove the printheads and check underneath the carriage and under the printheads themselves. Remove any jammed media.
Jan 22, 2010 | HP OfficeJet Pro k550 Printer
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Keep getting message rear draw open
If you pull the fuser out, look at the bottom of the sliding mechanism for a bent metal tab that actuates a switch when you close the rear drawer.
They get bent pretty easily.
Jan 22, 2009 | Kyocera FS-3900DN Laser Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Won't print
ok, i just tried this and it works--
pull out paper drawer, in the back of the paper drawer there is a rectangular shaped blue button located just right of center. the symbol on it is a lock. this button can be pushed forward (away from you) or backwards (towards you), push it backwards towards you til it clicks in place.
return paper drawer and print.
this solved it for me-
hope this helps
Sep 28, 2008 | Brother HL 5250DN Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
Paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Oct 16, 2007 | Lexmark X3470 All-In-One InkJet Printer
Sharp FO-4400 Fax Logo
187 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
