Question about Sony Cyber-shot DSC-W55 Digital Camera
Access message Hello, this problem was posted multiple times (the Access message followed by the lens opening and closing multiple times) the pressure application to the lens didn't do it for me, any other suggestions ?? QA
  • 2 more comments
  • Anonymous Apr 06, 2008
    We power on the camera, the "access" message shows in the display area, and then the message "turn power off and on again" diplays. the lens slides in an out several times. Batery is charged. everything else seems normal.
  • duuy May 30, 2008
    LENS KEEPS OPENING AND CLOSING. ACCESS SHOWS THEN
    IT SAYS TO TURN CAMERA OFF AND THEN ON AGAIN.
    THAT ISN'T DOING ANYTHING
  • Anonymous Jun 03, 2008
    When camera is turned on "Access" message is displayed, then lens goes in and out several times and then message turns to" Turn the power off and on again". Have done this 10 times and no change, can still view pictures on camera and everything else works, battery is fully charged.
  • Anonymous Jun 06, 2008
    Same Problem
  • 74 Answers
Turn on
take hold of the end of the lense and gently pull and twist you may hear it click but dont force it then turn it off and on again this may solve the problem.
Posted on Nov 03, 2008
Multiple attempts are needed to open facebook application, why??
Some times Facebook has its own problems which cause it not to load.
Aug 13, 2012 | HP Computers & Internet
Every time i try and send a message off my phone a message comes up saying 'number of applications reached.....what the hell does this mean?
Hello thanks for using fixya
This problem is may be because of to open multiple applications at once (shown by a "two overlapping squares" symbol in top line of main display)
You may have opened several without shutting them down and reached a maximum.
Simple solution is Click on Multitasking button (grid shaped button at top right of main screen) to see what applications are open and close them down.
If this doesn't work, simple power phone off, then on it and see it will be surely work
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using
Feb 01, 2011 | LG GD510 Cell Phone
I am fremarclinton.nc.rr.com. I am having a problem about which I already told you regarding being unable t access a file which Lotus told me was already open when I tried to open it. This I have told you ...
Is Lotus notes open now? Is this computer a part of a network and connected to other computers at this time? If you know and can see that you don't have this file open, but it's a shared network, then the file could be open on another computer on the intranet (inside network)
These would be most common issues..
Thank you for visiting Fixya.com
Nov 11, 2010 | Computers & Internet
When camera is turned on the lens opens and closes several times and then an error message appears: "Turn the power off and on again." When this is done, the camera does the same thing - lens opens and...
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 20, 2010 | Sony Battery (844986068551) for CyberShot...
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Sms problem
Nokia N95 is a Symbian handset. You might had opened many applications at one time which are consuming a lot of space on your handset. Try closing some applications or removing one-two applications from your handset and see if if works. Other then this you can try out expanding the memory for your handset.
Jun 07, 2009 | Nokia N95 Cellular Phone
I receive ''access'' error
The "Access" will stay there until your camera passes it's self lens test. The test runs 3 times, then gives up with an error message. The cause of this problem is most likely a grain of sand somewhere in the lens. Only a camera tech could possibly ever hope to find it. Replace the camera lens.
Nov 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
I had the same "access" problem as everyone else - but here's the real way to permanently fix this problem when banging and smacking it barely works.
1 - Remove battery and memory stick. Back up the mem stick if necessary or paranoid.
2 - Using a small Phillips head screwdriver, remove all of the screws you see from the front (lens side), right and left sides of the camera. Then remove all three of the covers and place aside.
3 - Clean and remove all dirt & dust in and around front of camera, paying special attention to areas close the lens and lens housing areas.
4 - Insert battery and close the battery cover and then PLACE THE CAMERA RIGHT-SIDE UP ON A FLAT, NON-METALLIC SURFACE, MAKING SURE THAT YOU'RE NOT TOUCHING ANY OF THE EXPOSED CIRCUITS OR WIRING TO AVOID POTENTIAL SHOCK. This isn't a danger issue, more of a cover-my-*** related note. When I did this for my DSC-W55 I touched it just about everywhere without receiving generating anything close to a shock.
5 - Press the power button. If lens does open fully and you're still receiving the "access" message, continue powering off and on while using a toothpick or compressed air to remove remaining dirt and dust particles.
6 - When you're DSC-W55 is back in business - and after you've tested it multiple times via several on/off cycles, begin replacing the covers one at a time. The trick is to replace one cover, then to test the camera again via several on/off cycles. Do this until you've reattached all covers and camera is fully operational once again.
Tip - you may find success early by varying the tightness of the screws for each side's cover as you move along the on/off cycle process.
Dec 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
63 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
