Question about Samsung LN-S3241D 32 in.LCD HDTV
I can not get the pitchure size to fit the tv. I have tryed to fit using the p-size on remote with no avail. There is only a small box with a pitchure on the screen.
  • 87 Answers
P size only works w video inputs , not tuner input. Sounds like you have text captions on too
Posted on May 13, 2010
Adjustments for picture size unavailable
Option 1 - reorder the remote online
Option 2 - test different universal remotes and codes. The easiest way is to use the smartphone universal remote apps. You may eventually find the right code for your television that allows you to access the menu and the feature you are looking for.
Good luck.
Dec 02, 2015 | Emerson Televison & Video
Can i fix picture size without remote using menu on tv
You should have a remote control to select the aspect ratio to picture. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name" of your device, in the search box [at the top right] of the display window and press Enter. It will make surf easy.
Jun 04, 2015 | Toshiba 32A33 32" TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
My tv's picture does not cover the entire size of the tv. The picture that shows is the size of a square and my television is a rectangular size. How do I widen the picture?
there should be a button on your remote that adjusts the picture to fit your screen. They have that on most tv's. Are you using a cable box? your cable box also has settings depending on what your using. 1080i, 720p? does it do the same thing with a dvd player or game console hooked up?
Mar 02, 2011 | Sylvania LC370SL8 37 in. LCD Television
Remote was lost. Tried to adjust the station and now I cannot get the TV to go to channel 3 so converter box will not work. Itied a universal remote did not work. Help
I assume, that the TV is skipping chan 3 when using the Channel buttons on the TV.
You can try 2 things.. First see if your converter box will use chn 4. Usually there will be a very small switch on the back of the box marked with a small 3 on one side and 4 on the other. If so, use that till you get a replacement remote.
If that's not an option, you can also, Re-scan the channels on the TV. to find all available chn for memory.. BUT FIRST making sure that the converter box is on and working.
The TV shuold then detect that there is a signal on chn 3 and make it available to the chn buttons on the set.
You will have to use the menu buttons on the set to do this.. Hopefully one of the buttons is the menu call up, then you use vol or chn buttons to navigate it.
Hope this helps
Dec 03, 2010 | Televison & Video
I can't switch the picture size. When i hit the pic size button, it tells me it's not available. I tried changing the pic size with the tv/video input on our dvd, but it won't change it when its on out hd...
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Nov 10, 2009 | Toshiba 57H82 57" Rear Projection...
I have a 52" samsung that is 14 months old. for some reason it is out of sync. the picture is too wide and does not fit cable shows or dvd's properly onto the screen. tried different picture size settings...
FCC says it only has to display a picture, with 16 formats it tough to get it to ever fit right, use 16x9 or full on TV remote , then 16x9, stretch 1080i on cable box
Jul 27, 2009 | Samsung LN52A650A LCD TV
HD not fitting on screen not sure of settings
Both the TV and Satellite box will have various size settings. The box remote probably has a button devoted to it.. could named several different things, (aspect, size,picture,etc..) on tv menu you will find a section devoted to picture size or you may even have a button on your tv remote just like the sat box does, most do.
Apr 30, 2009 | Televison & Video
Picture size
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 05, 2008 | Toshiba 50H82 50" Rear Projection...
Samsung LN-S3241D 32 in.LCD  HDTV Logo
63 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
