Need a manual for LG Wm-1290 FHB
Need an instruction manual for LG Wm-1290 FHB Please, is it poss. to download it?
Thanks
haydnt
  • maizelinp May 12, 2010
    I too would like to know if I can download the manual, since I lost mine.
3 Suggested Answers
  • 112 Answers
SOURCE: LG washing machine, WM 1371(6)FHB, 7 years old,
Some of the LG washers have a 10 year warranty on the motors and your issue could be fixed for free by LG if your problem is the motor.
Open the door of the washer and spin the inner tub fast and listen to find out if you hear a bearing or if it is the motor.
If the bearing is bad, labor and parts would be around $490 - $700. This is a major repair because the bearing is sold with the back half of the outter tub assy. So, you just cannot replace the bearing.
If its the motor, call LG about a posible warranty repair.
Good luck.
Posted on Jul 24, 2010
  • 6277 Answers
SOURCE: model # wm 1290 fhb
Sorry but I do not know your particular machine BUT I would suggest as a first step that you CLean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 22, 2011
I have an LG Intellowasher - WM-1372 FHB, the door release hook has broken off, so the washingmachine door will not close or lock. What can I do? Can I purchase a replacement door for this model. Please...
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories (Yello Pages?) for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 15, 2011 | LG Washing Machines
Model # wm 1290 fhb CL appears when plugged in no control buttons respond
John C
Feb 22, 2011 | LG Washing Machines
LG washing machine, WM 1371(6)FHB, 7 years old, sounds like main bearing on the way out. Is it economical to repair? I'm mechanically/electrically competent.
Good luck.
Jul 23, 2010 | LG Washing Machines
SERVICE MANUAL FOR LG WM-2032H Front Load Washer
Hi dear.If you know what you are doing,please click the link below.Ihope thathelps.Thanks. http://dl.owneriq.net/2/2d746ee4-b30a-9074-b554-f3ce77a57775.pdf
Apr 03, 2010 | LG WM-2032H Front Load Washer
Need link for manual for LG washer WM 1812 CW
You could download the manual from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WM1812CW-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 30, 2009 | LG WM-1832C Front Load Washer
WD8074-FHB washing machine SE on display
LG washing machine error code SE indicates a “motor fault” although the code also says it could be a main PCB fault.
They recommend to... “try the motor first”.
It’s vague and you really need an engineer to try and sort this one.
You can’t possibly justify “trying the motor first” if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
