Question about Samsung HL-P5063W 50" Rear Projection HDTV
When turning on the televisionm, I get a high-pitched whirring sound coming from the TV. It lowers in pitch, then kicks back to high pitch and lowers again. It will do this two or three times. Then the righ green flashing light will flash for about 10 seconds. The TV will turn off momentarily and then repeat the above action, two or three times, then both green lights will start flashing. I can then hit the on switch on the remote and it will repeat the first actions acouple oif times then come on. After it comes on, the color will fade a couple of times, then the TV works well after that. I have replaced the bulb, color wheel and ballast already.
  • d_mccarroll May 20, 2010
    OK digital board replaced, same problem still exists. Now I am noticing that while the TV is on, I can sometimes hear the whine change pitch and the colors fade in and out while this is happening. It is as if the color whell is slowing down and speeding up intermittently. I have replace the wheel twice. So am fairly sure the problem lies elsewhere. Also, I am thinking that the bulb is not getting power at first and that is what is causing the TV to cycle.....Does this sound like a possible power board problem?...I am think along that direction...
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa Usually a loud high-pitched sound comes from either the color wheel and/or the ballast. To start with open the lamp door and check the lamp door switch, check if the lamp is working. However, from what you have described it seems to be an issue with the Digital Board going bad, it is the large metal tin covered board in the rear of the TV where the VGA Cable is plugged in. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 12, 2010
  • d_mccarroll May 12, 2010
    I have already replaced the color wheel and the ballast with new units as well as the bulb. I am guessing that it is the digital board as that is the only component I have not changed yet. Is there a resource I could use to obtain this board??
  • Rylee Smith
    Rylee Smith May 13, 2010
    You can buy the parts from this link. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
Picture ok but loss of sound with high pitched buzz
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Feb 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
High pitch sound coming from back of TV?
it could be either the coils on the yoke of the tube or the flyback. flyback would need to be replaced it that is the problem
Apr 19, 2009 | Curtis-Mathis CM19011 TV
52 inch rca scenium wont turn on
this is an indication of a shorted horizontal ouptut transitor and bad flyback transformer
Mar 14, 2009 | RCA HD52W58 52" TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
105 people viewed this question
Henry  Thomas
Henry Thomas
