Question about Vacuums
Why does a ceiling fan hum in low but not in medium, or high speeds
    Genius:
  • 1,341 Answers
Because it may need maintenance. I would suggest you remove it and give it some lubrication in the motor and all moving parts. Once you do this it would hardly hum. Hope this helps.
Posted on May 12, 2010
Height adjustment slips out of low and medium to high carpet position
Owner's manual troubleshooting
no manual? try manuelslib.com
You may have the adjustment device loose look for a screw or bolt to tighten it but not so tight as to stop any movement.
Mar 17, 2015 | Vacuums
Can I fix the high, medium, low level switch on vacuum piece?
The height adjustment lever on Kenmore Power Nozzles is one of the machine's weak points. It's not well made as far as being protected from dirt and dust and moisture. It's always easier to move these things when the vac is on it's side or at least with the front end in the air. That takes the pressure off the adjuster. The mechanism may need nothing more than to taken apart in the presence of a good air compressor which can be used to blow out any of the aforementioned debris.
Nov 11, 2013 | Kenmore Vacuums
I LOST MY REMOTE CONTROL, INSIDE THE LIGHT THERE IS A PLASTIC HOUSING WITH CIRCUIT BOARD AND DIP SWITCHS THERE ARE SOME NUMBERS ON THE OUTSIDE, FCC NO CHQ8BT7051R MODEL NO UC7051R SERIAL NO...
i got a new remote switch box to put inside the fan, wiring in the lights was a snap but i have a red pink grey and yellow wire that control the fan and i should have tested the wires before i unplugged and re wired the light because the fan was running on low speed when we flipped the switch on thewall sending power to the fixture itself now i suppose there are only 16 different combonations to send power to the fan unless you factor in that maybe the red and pink are high and low respectivly and grey is "close" to black and yellow is white then you gotta have a switch to go high or low, God save us all and bless the person who can tell me what the other 4 wires go to
Apr 18, 2011 | Vacuums
I need to replace the remote control (UC7083T) of my Hampton Bay Sidewinder 54 Ceiling fan. Could you pls tell me where to buy one? Thanks
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Feb 01, 2011 | Vacuums
I have a model 484 709 UPC 792145330547 The fan/light is close to ceiling (instalation). Their is supposed to be an "o" ring to remove the fan/light from the celling. I cannot find it!!! ...
Remove the cowl at the ceiling by removing the screws in the cowl (very close to the ceiling). Use caution in removing them as the weight of the fan may be carried by these screws. Depending on the style, though, the weight may be borne by supports beneath the cowl. Either way, this will get you access to the wiring, allowing you to change out/remove the fan. If the fan and cowl are together, and close to the ceiling, there is usually a method of hanging the assembly while the wiring connections are made during installation. Look for a hook that the screw hole will go over, supporting the fan.
Best regards,
--W/D--
Jan 19, 2011 | Vacuums
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
Who makes Heritage Ceiling fans?
unfortunatly there are many manufactures that have a "heritage" model fan ... like casablanca, minka aire, concord and emerson ... even Kmart sells a fan called Heritage (not a bad fan) ... of the above, casablanca has a high end model called "heritage" and that name is likely the domanant brand .. if you can find a model number then it can be isolated better ... .
here is info on that one
Casablanca Heritage Ceiling Fan
http://www.carolinarustica.com/product.asp?pn=CB-C19624F&sid=BECOME&utm_source=Become&utm_medium=cse&utm_campaign=MerchantAdv
Apr 15, 2010 | Vacuums
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Mar 05, 2008 | Vacuums
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
