Question about Xerox DigiPath Scanner
I have a digipath scanner 2000 and i need to replace the paper path sensors, I need the part numbers and possibly a scematic or procedure.
    Genius:
  • 1,354 Answers
Hi
go to folowing link you will get all spec of your scanner
http://www.xerox.com/downloads/usa/en/d/digi2000.pdf
Posted on May 12, 2010
  • Tim Thies May 13, 2010
    I need a scematic of parts not a spec sheet.
  • Tim Thies May 17, 2010
    I still need the paper scanner flag part info for the Digipath 2000
Light flashes and it says the scanner door is open but everything is closed
More common reasons are paper jam, dust/dirt, or a faulty sensor.
So, check for even the smallest pieces of paper, especially in the scanner area, use compresser air if necessary and clean the scanner glass.
Your sensor could also be broken/faulty. Not certain if the sensor is a user-replaceable part.
Hope this helps.
Aug 10, 2009 | Canon DR-2580C Path-Through Scanner
Error P00
A few easy things to try. First off, have you power cycled the unit since checking for a paper jam? Often that will clear false errors. If not, look for the sensors. They should be somewhere along the paper path, and consist of a plastic lever that will be pushed down as the paper moves past them. Usually these levers have springs attached - if the spring comes off, it will register a paper jam. You'll probably have to take off some of the housing to get to them. I'm not sure this will help much, but since I found it I'll post it. The user's manual: http://edocutek.com/Manuals/DR6080_9080C_UG.pdf If the sensor needs replaced (most often due to something simple like a piece of plastic breaking on it), you can order new sensor PCB assemblies (sensor and its small control board) here: http://www.precisionroller.com/manufacturers/canon-dr6080.html They also sell a parts manual, but it's a bit pricey.
Sep 08, 2007 | Canon DR-9080C Path-Through Scanner
Scanner No Paper Detected Error
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Jul 30, 2009 | Panasonic KV-S3065CL Path-Through Scanner
My Canon Dr-9080C isnt pulling the paper into the scanner. The input try elevates, and then returns to it's original position, without the paper being pulled into the scanner, as if there wasn't any paper...
The scanner is assuming there is no paper. Just under the rubber rollers, in the paper tray there is a paper sensor. Clean that area with a damp cloth. Keep some papers and try "count-only". It it works then sensor is okay, else, you need to check the sensor.
S. Mohan, India
Jul 12, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Get paper path error when path is clear & clean.
There are two types of sensors, optical and mechanical. Sometimes the mechanical sensor get stuck and give a message to the scanner that paper still remains inside the scanner. Check if any of them is stuck, Blow air from a dsiatance so that any shreds of paper is foreced out.
S. Mohan, India
Jun 22, 2009 | Bell & Howell Sidekick 1400 Path-Through...
Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Oct 09, 2008 | Canon DR-3080CII Path-Through Flatbed...
Scanner out of paper
please check if all paper sensor arms are present and not blocked.
Sometimes on of then will be missing or broken.
The center sensor just below the separation pad is the paper end sensor. If this sensor don't work, the scanner do not stop feeding.
It means you scan on sheet, the scanner eject it and then the feed motor do not stop because the paper end sensor don't record a paper end.
Another case may be a driver error. In case you are using XP and installed a new service pack please check your SCSI driver versions (ASPI32 and so on) and TWAIN resp. ISIS driver and update them.
Jul 03, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Persistant error: "Document remains in scanner. Open door and remove document."
I get calls about this all the time. The most common reason for this is the shiny reflector for the Ending Sensor is dirty. It is best to clean this with a cotton swab and a few drops of rubbing alcohol.
Although it is possible that one of the sensors has gone bad. The Panasonic User utility is very basic, but if you have access to the Service Utility it will help pin-point which sensor is causing the problem.
Out of all the calls I've taken relating to this same issue, only two or three situations have been resolved by replacing the sensor - all the rest have just been dirty.
Jan 26, 2007 | Panasonic KV S2025C Path-Through Scanner
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
