Question about LG enV VX9900 Cellular Phone
Reset Symbol Recognition?
My LG enV appears to remember phrases or symbols that I've typed and will automatically. Like, if I type "=" my phone will automatically type "=)" and when I type "-" it goes "--can't help you there". Help! It's really annoying!
  • Anonymous Apr 04, 2008
    I have the same problem. My $ becomes "$80", apparently because I sent $80 as part of a text message once. Just now, I had another occurrence where I sent "I40", and now the quotation mark symbol produces "I40".
    I was able to confirm that this strange symbol problem seems to only occur in the text messaging interface. I do not see this happen in the notepad, wireless email, or wireless chat.
This happens because you have your enV text entry mode set to "Word". Undoubtedly, you did this for the same reason I did - to get T9 mode working when you text from the front keypad with the phone CLOSED, instead of from the QWERTY keyboard with the phone OPEN.
If you go to Messages->Settings->ALL Msg->Entry Mode and set it to Abc instead of Word, your problem should go away.
Posted on Apr 04, 2008
Thank you - this fixed my problem!
Posted on May 12, 2008
SOURCE:
Touchscreen is not working,.how can i reset the ph one
You can access the service menu by opening the handset and pressing symbol, 3, symbol 3, type program 99100 then press send.
Feb 17, 2011 | LG VX9600 Cell Phone
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
How do I do a master reset on my LG ENV 9900?
http://www.youtube.com/watch?v=Nmrf7gfIVzA&NR=1
press the symbol key
press the 3 key
press the 3 key
type 'program', press 'send.' press 000000
Jun 03, 2010 | LG enV VX9900 Cellular Phone
Lg 9100 keybo i cant figure out a symbol showing on my phone , its in between the sd card symbol and the music symbol. it looks like 2 texts symbols, but there not. almost looks like a letter on top of...
lg 9100 keybo i cant figure out a symbol showing on my phone , its in between the sd card symbol and the music symbol. it looks like 2 texts symbols, but there not. almost looks like a letter on top of another
Mar 21, 2010 | LG enV VX9900 Cellular Phone
Stays on verizon symbol wont turn on
it doesn't go out after a couple secs? or are you looking to change the pic after it boots? if the latter you can go to verizonwireless.com and use there manual on line for directions
May 03, 2009 | LG enV VX9900 Cellular Phone
Strange symbol appeared, battery life now much shorter
Yes! That's definately your bluetooth indicator. Btw, there should be an icon glossary. try setting and tools/phone info/icon glossary. As far as the BT indicator check your bluetooth menu and disable it, assuming you have no BT peripherals as evidenced by your lack of understanding regarding the BT icon and effects of peripheral hardware on battery life.
You may also wish to do a little research on crop circles. But try not to get too weirded out.
Apr 15, 2009 | LG enV VX9900 Cellular Phone
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Typing * symbol
This is a problem with LG's T9 autocomplete database that affects other LG phones as well.
I have a solution, but it's not for the feint of heart. It requires BitPim (bitpim.org). BitPim is a great app that does a lot more than fix this problem. It can be used to backup the data (calendar, contacts, notes etc) on your fone onto your own computer as well. Be warned though, it's not very user-friendly and it can be a hassle to get it set up at first.
You can learn more about BitPim from here.
Anyway, assuming you have BitPim working and talking with your phone (don't ask me about this part, see the link above)
Open BitPim, and look through the phone's Filesystem. This selection isn't shown by default. On a mac (and probably PC too), go to the view menu, then select "View Filesystem". "Filesystem" with a brown drawer icon will appear in the left hand column of the main window.
After the data is loaded from your phone, scroll down to "t9udb" folder in the second column. In the pane that loads, right click on "t9udb_eng.dat" and delete it. Restart your phone and the problem will be gone, and you can go back to using T9.
You will lose your saved t9 autocompletes, but you'll also get rid of this bug temporarily. This is a recurring problem, so you might have to delete this file every once in awhile. One way I've found to prevent this problem is to always type a space after a symbol. IE To type out "$260", I would type $ - space - CLR - 2 - 6 - 0
As annoying as this is, using this method is better than having to deal with all the weirdness that happens through regular use.
Good luck
Apr 06, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
566 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
