Question about NEC Soundbar 70 2 Speakers
No sound through NEC Soundbar 70
I just bought 5 NEC MultiSync LCD1970NX with a MultiSync Soundbar 70 attached and can't get any sound. Sound works through speakers plugged into the computer, but can't get it to come through the soundbar. Help!
5 Suggested Answers
mrninja
  • 600 Answers
SOURCE: bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Posted on Apr 13, 2009
  • 13 Answers
SOURCE: how to get sound
You can't get sound from your monitor ha! ha! you have to use a sound card and also an output device such as a speaker or a headphone.
Posted on Dec 31, 2009
rcw1962
  • 2571 Answers
SOURCE: I have a NEC MultiSync 70GX/90GX LCD Monitor and I
Plug the audio lead in and check your default playback device
Posted on Jul 26, 2010
rajsun22
  • 73 Answers
SOURCE: My NEC MultiSync LCD1970NX monitor
If the system is booting up and if you see the "NUM LOCK" key lighting up in your keyboard then the system is working fine. The problem is with your graphic card. Check and repalce it. If not, the problem is with your monitor. Check the warranty and ask for a replacement.
Posted on Mar 04, 2011
How do I replace sound bar on monitor?
Deb Powell,
Reverse the steps listed below. They are for connecting the sound bar.
1. Working from the rear of the monitor, attach the Soundbar aligning the two slots with the two tabs along the bottom rear of the monitor.
2. Slide the Soundbar to the left until it snaps into place.
3. Connect the Soundbar with the power brick.
4. Plug the power cables of the power brick into a nearby outlet.
5. Insert the lime-green mini stereo plug from the rear of the Soundbar into the computer's audio output jack.
NOTE: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only.
NOTICE: Do not use with any device other than Dell Soundbar.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2016 | Dell E197FP LCD Monitor
How do you open lcd1970x
All it requires is to remove all the screws on the back of the monitor and it will open somewhat, there will be some power wires that may need to be removed but the plastic outer trim around the screen will need to be gently pryed off. You didn't say why you wanted to open it up but I will assume that it isn't powering up. If this is the case most times this will be caused by faulty diodes, I believe there are 6 and a couple of smaller ones. You can tell if they are bad if they are swelled on the end. I would recommend to replace all of them and use Japanese gold rated and should cost around $25 USD
Mar 17, 2014 | NEC MultiSync LCD1970NX Monitor
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
My NEC MultiSync LCD1970NX monitor went black while in use and green power light is flashing.
Mar 03, 2011 | NEC MultiSync LCD1970NX-BK (Black) Monitor
How to get sound through my computer with a nec multisync lcd 1570nx screen
Dec 31, 2009 | NEC MultiSync LCD1570NX Monitor
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Open Questions:
NEC Soundbar 70 2 Speakers Logo
Top NEC Audio Players & Recorders Experts
richie46
Trippy Tripp
Outback Jack
Outback Jack
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
