Very slow filling
Brand new Whirlpool washer model 5200 is filling VERY slowly. No problem with our water pressure.
  • 410 Answers
Right where the two supply hoses screw on the back of the unit. Remove them and clean out the little screens that keep chunks of dirt out. Your water supply will be back to normal. Remove them only if you h-a-v-e to.
Posted on May 12, 2010
Maytag Ensignia top loading washer water hammers and fills slowly.
Check the water flow coming out of your water valves on the wall. Once in awhile a faucet washer comes loose in the valve causing "flutter". Check the flow through the hoses before they get to the washer.
Sep 24, 2017 | Maytag Washing Machines
Water fills slowly
could be your water pressure at the valve for the washer. make sure the valve is all the way on. if no better there are screens in the hoses to the washer make sure they aren't clogged
Jul 14, 2012 | Maytag Washing Machines
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water comes out wash cycle good but slow at rinse cycle
do you mean filling the washer up or draining it out?i think you mean filling it up,on washers just the cold water is used to fill the washer on the rinse cycle,you can shut the water down and remove the cold water line and see if you can clean out the screen in the washer water valve,also while you have the hose off,stick it in the washer and open the valve to see how the pressure is,if it's coming out strong then the problem is in the washer and you should change the washer water valve,if it's coming out slowly then you have a problwm with the house water valve and need to change that out.let me know what you find
Aug 29, 2010 | Whirlpool LTE5243D Top Load Stacked...
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
When not in use, my washer begins to slowly fill with water.
you either have a very poor water pressure to the machine or the fill valve is not closing completely and will need to be replaced.
Mar 19, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
G e washer fills slow on 2nd rinse
check volts at water valve in first rinse ..note that ... when in 2ed rinse check volts to w. valve and see if theres any difference in volts to valve... also compare the water pressure coming in washer ... how much pressure difference.. lot, little ? generally water valves work or dont work in all cycles ,,,this a new one for me post your results
Sep 01, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
