Question about KitchenAid Ovens
Kitchenaid Superba walloven/microwave - problem with big oven.
Bottom oven displays 177 degrees rather than the default 350. When I try to change it, I get and "Err" message
I lost power and had the same problem. 177 degrees and ERR whenever I tried to change it. Reading the manual, I noticed that it was showing the degree symbol instead of F. When you hold down the broil/maxi/econo button for five seconds, it changes to F and then it worked perfectly. Makes no sense, but worked without any repairs needed.
Posted on Jan 21, 2012
  • mumzypie
    mumzypie Aug 26, 2012
    I had the same problem but when i had to open the oven door and hold down the broil/maxi/econo button for 5 seconds to reset. Great advice. My repairmen said it would be over $600 to replace boards.
  • Gary Dyjak
    Gary Dyjak Jan 27, 2013
    This worked for me. The oven door had to be open for the reset. Thanks!
5 Suggested Answers
SOURCE: Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Posted on Jul 11, 2009
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Posted on Jan 07, 2009
SOURCE: Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Posted on Nov 18, 2009
Master_Tech
  • 770 Answers
SOURCE: Oven light bulb
Check your email
Posted on Jun 15, 2008
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
My Frigidaire electronic single wall oven FEB275ASB won't stop beeping. It displays a P4 error
F4 Shorted oven sensor (RTD) Check for shorted wiring between EOC and RTD. Check resistance of RTD using resistance table. If resistance test is correct and wiring is good replace EOC TEMPERATURE °F RESISTANCE ω 32 ± 1.9 1000 ± 4.0 75 ± 2.5 1091 ± 5.3 250 ± 4.4 1453 ± 8.9 350 ± 5.4 1654 ± 10.8 450 ± 6.9 1852 ± 13.5 550 ± 8.2 2047 ± 15.8 650 ± 13.6 2237 ± 18.5 900 ± 13.6 2697 ± 24.4
Sep 20, 2009 | Frigidaire FEB27S5A Electric Single Oven
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Feb 09, 2009 | Ovens
Dec 20, 2008 | Ovens
Oven light bulb
Check your email
Jun 15, 2008 | Ovens
Re: oven
the temp probe ( rod sticking out of rear wall inside oven ) should ohm out at 12-1300 ohms at room temp. the other possible cause is the heat relay on the control board is bad .this does not display a fault code.
Jan 17, 2008 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
313 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
