Question about Refrigerators
PRIMA LPR100/1 All the contents have frozen overnight but the temperature control setting has not been altered.
3 Suggested Answers
  • 1073 Answers
SOURCE: Candy fridge has overnight frozen
replace the cold control
Posted on Apr 12, 2008
SOURCE: contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Posted on Oct 30, 2008
Can you tell me how I can adjust the temperature control for my fridg? All of my contents are getting frozen
It should have an adjustment by either turning a knob or a digital push button. The problem may be in the control itself letting the compressor run to much, or in the damper assembly controlling air flow from freezer to fridge v
Oct 17, 2017 | Refrigerators
Samsung double door model SR-L709EVSS - Freezer is chilled but does not make ice. Ice/frost packs on the wall of the freezer. As soon as I open the freezer door the temp defaults again.
Hi.. this can be caused by a number of things, however, that packed ice on the wall leads me to think this is a frozen solenoid on the water intake..
The most difficult thing about the fix, is where to put the contents of your freezer for overnight.. check with your neighbours, or get a large cool box.
the fix is to simply defrost the freezer THOROUGHLY.. it cannot be rushed with a scraper as the ice is within a closed valve and possibly backing up the water pipe by an inch or so.. make sure that the ice bucket fill wire is up, so that it does not try and make ice when you let it thaw properly overnight, dry it thoroughly and then set the freezer temperature to it's warmest setting for a few hours, then a little cooler, and so on, until you get to the desired temperature.. then drop the ice gauge wire to trigger ice making.. check back in a few hours to see if any has been produced
When you return the food, please pre-sort it, into shopping bags, each bag representing a shelf so you can fill the freezer swiftly.. then the ice that's made won't melt slightly, and then refreeze, sticking it to the ice bucket.
Apr 23, 2017 | Samsung Refrigerators
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
Hello We have a prima donna machine and
Check your programmed temperature setting; perhaps your machine has been set at low or medium.
Following are the instruction for Setting the Temperature from the manual for the ESAM6700.
1. Press the P button to enter the menu;
2. Press the < or > until "Set Temperature" is displayed;
3. Press the OK icon;
4. Turn < or > until the required temperature (high, medium, low) is displayed;
5. Press the OK icon to confirm (or the ESC icon to cancel the operation);
6. Press the button to exit the menu.
For a hotter coffee, before delivery rinse the appliance through by pressing the Rinse icon and confirming with the OK icon. Hot water
flows out of the coffee spouts and heats the internal circuit of the machine so that the coffee delivered will be hotter.
For an even hotter coffee, heat the cups by rinsing them with the hot water.
Mar 22, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
Contents of crisper drawers are frozen
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Frozen Fridge
the temperature controlis most likely bad since you cant control it. the control is the knob you turn to set the temp with. you should be able to replace it yourself fairly easily.
Dec 20, 2007 | Refrigerators
GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Nov 01, 2007 | Refrigerators
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
