Question about GE Refrigerators
Ge model PSS26SGRE SS fridge not cooling
Ge model PSS26SGRE SS inside lights are on but fridge or freezer not cooling. Inside digital control panel is not on, fan and compressor not coming on.
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
SOURCE: GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
Posted on Jul 22, 2008
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
tech master
  • 120 Answers
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
Posted on Oct 14, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
GE refrigerator model number PSS26SGRE SS quit. Lights come on and only digital readout is hours
the mainboard/motherboard in the rear area needs replacing the number is G.E.part # WR55X10942 it merely unplugs and plugs back in with 4 to 8 harnesses depending on your model and accessories
Mar 04, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
