Question about Definitive BP7004 Main / Stereo Speaker
Sub not working
I have a pair of definitive technologies 7004's for my left and right speakers. I just bought them from a guy on craigslist. He says he had no problem with the sub's.
I'm not using the optional LFE input on my pair of mains. My reciever has my mains set to large, and sub is set to none. One sub works in one tower and not the other.
When I plug the bad tower into the wall, i can hear the amp 'pop' like the DT site says is normal. the red light is on, on the back, which signals the amp is on. however the sub doesnt ever activate. no vibrations. If i take my other 7004 and swap it in place, using the same speaker connection and electrical socket, the sub works fine.
This tells me the amp is ok? but something else is messed up? How do I troubleshoot this? I'm afraid to unscrew the back plate and mess something up.
when I transported them in my car on the way home I had the speakers resting on their backs. I was afraid to rest them on their sides since they have speakers on the sides.
On the back of this tower the level knob axle was a little bent. meaning when you turned the knob it wobbled a little. I bent it back straight and it feels like it funcitons just like the other tower. the knob is still turning something in there. it doesnt 'feel' broken.
any help would be greatly appreciated!
Thanks
Rob
2 Suggested Answers
  • 54 Answers
SOURCE: placement of definitive supercube 2
Make shure your crossover on the amp is set at 80hz. If closer to side walls you will get more response but may be muddy. Make sure it goes low enough to comliment the klipchs.
GOOD LUCK
BIGRED
Posted on Apr 11, 2008
Where is the reverse switch on my black & decker 1/4 7004 drill type 1
The now vintage B&D model 7004 type 1 was a single-speed, non-reversible drill. There is no reverse switch.
Mar 21, 2015 | Black & Decker Drills
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
What colors are ignition and 12 v
Ignition wire for the radio is RED.
The constant 12v is YELLOW.
BLUE is the remote/power antenna.
ORANGE is for the dimmer.
PURPLE pairs are right rear speakers.
GREEN pairs are left rears speakers.
GRAY pairs are right fronts and
WHITE pairs left fronts speakers. Hope this helps.
May 19, 2011 | Kenwood KDC-MP208 Car CD/ MP3 Player
The cone is busted15"
It might be cheaper and easier to snag a whole speaker or even a pair on eBay or craigslist than to locate and obtain the exact driver.
examples:
http://cgi.ebay.com/JVC-SP-7700-Main-Stereo-Speaker-/270738470371?pt=Speakers_Subwoofers&hash=item3f094535e3
http://joplin.craigslist.org/ele/2263290479.html
Apr 21, 2011 | JVC SP-7700 Main / Stereo Speaker
I need the wiring diagram for the Pioneer CD player model DEH P6400
Red= acc 12v
Yellow = constand 12v
black = ground
blue/white = remote turn 12v out.
purple pairs are the Right rear speaker
Grey pairs are the front right speaker
white pairs are the front left speaker
green pairs are the left rear speaker
orange white is the dimmer.
Mar 17, 2009 | Pioneer DEH-P6400 CD Player
Replacement speakers
You should be able to use any of the "bookshelf" speakers to replace the Front Left/Right and Rear Left/Right. I would go ahead and get a dedicated Center speaker. I bought a Pioneer center speaker and a pair of KLH 3-way bookshelf speakers at Radio Shack at low prices. I also bought a pair of Insignia 3-way bookshelf speakers. I put this all together with a Durabrand Home Theature system (dumping the satellite speakers). There is better range and a much fuller tone with these speakers versus the originals. Even if you hadn't lost the speakers, I would recommend this as a good upgrade.
Hope that helped.
Leonard
Aug 12, 2008 | Durabrand HT-3915 System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Need A Wiring Diagram
Hi Matt,
I assume you have probably got the answer but just in case you haven't. I just opened the box on a unit someone gave me and I have the harness. From left to right the first pair (top and bottom) are the left speaker + top and left speaker - bottom. The next two are the right speaker. The next two are left signal in and the last pair are right signal in.
I'm looking for an instruction manual if there even is one.
Brian
Mar 11, 2007 | Jensen XA92 Car Audio Amplifier
Definitive BP7004 Main / Stereo Speaker Logo
88 people viewed this question
Top Definitive Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob
Rob
Scott
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
