Has my lcd32805hd tv got freeview - Televison & Video
Tv keeps turning off
If you can keep it on long enough, try changing the power-off sleep timer (via the remote control menu) to the highest setting (most modern TVs have this). It could be a component overheating or over voltaging in the power supply (I assume it's internal) so check for burny smells.
May 19, 2014 | Televison & Video
My LCD32805HD tv keeps staying on stanby
Main board to your TV should be checked. Sometimes it might need replacement. Contact any experienced service technician.
Jul 02, 2012 | Televison & Video
I cannot connect the dvd, freeview and tv wires so that they all work. I only have one scart socket at the back of the tv but have bought a scart adaptor to solve this problem. I cannot get my dvd to work...
If your freeview has two scart sockets,connect a scart from the freeview(marked tv)into the tv,then one from the dvd into the other scart socket on the freeview,the main aerial should go into the freeview and a flylead out into the tv.Hope this helps
Sep 11, 2009 | Sony DVP-NS50P DVD Player
Tuning an Accoustic Solutions TV
hi go to this site selct user manuals and ur model and get the full manual there
regards
http://www.nodevice.com
Apr 19, 2009 | Televison & Video
Manual for acoustic solutions lcd32805hd tv
You will need an HDMi lead running from the port on the back of your television to the port on a compatible DVD player/recorder, then toggle (keep pressing) the AV/Source button on the remote to switch the television mode to HDMi.
The HDMi port will be marked HDMi on the back of your television.
Jan 01, 2009 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
