Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer is making a high, metallic screeching noise
Not sure what to tell you except that it has done it before and gone away. It make that noise even when I took all the clothes out and even after resting all night. Any thoughts would be appreciated as I have 4 kids and 6 more loads to go!
Thanks,
Alicia
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on May 13, 2010
2004 Infiniti G35 Coupe: Metal on metal noise while braking and driving help!
i wouldnt drive the car much till inspected
would say you ran out of brake material on your pads
now up for pads and rotors
tyres off to inspect will tell how bad it is
Apr 16, 2017 | Infiniti Cars & Trucks
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
SCREECHING DRYER
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Apr 11, 2014 | Frigidaire Washing Machines
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My car is making high pitched screeching noise like metal scraping metal. I think it could be the E-brake because it only make the noise when the car is moving. I know it's not the engine because it makes...
it does not sound like the ' E-brake ' -- what it sounds like is a bad wheel bearing, or it could be something as simple as the brake pad wearing out. but I am going to put my money on the wheel bearing. take your car down to your local Midas or brake repair shop,, they do FREE brake inspections and it takes about 20 minutes to check 'em,, they will tell you if it is the brakes or if it is the wheel bearings. if it is the brakes then you have some time before they go out totally,, BUT if it is a wheel bearing - then you are going to want to get that fixed now,, it can cause a lot more damage if it goes to far.
if it is the bearing - make sure you find a repair shop that deals with and repairs this problem often --- stay far away from the dealership ( they will charge you a arm and a leg for the repair ).
c...
Feb 02, 2011 | 1994 Ford Escort
Metal on metal sounding clicking noise while the wheels are turning but only on the frot driver and passenger wheels. What is going on? It started out only on the passenger side and then after the tire...
Is the noise a screeching high pitch or a growling low pitch?
It sounds to me that the CV joints might be bad and you need brakes.
high pitch would be the brake warning tabs
the low pitch would be the brake pads are gone and you are on the rotors gringing away metal
May 21, 2010 | 2000 Nissan Altima
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Me GE elec. dryer is screeching, how do I solve this problem
First, stop using the dryer. It is telling you "I'm broken".
Several things can cause the noise you are describing:
1. Belt is slipping. Lost proper amount of tension on the tension pulley as spring has become weak.
2. Rear drum bearing has rubbed completely through and the drum is now riding on the metal support, This can cut into the drum support and trash it.
3. Tension pulley has got bearings that have gone dry (bad). Fix is to replace pulley.
4. Chance that the bearings in the motor itself have gone dry (Bad). Some you can oil and some are sealed. In either case, if they are making this noise, they are probably no good and motor needs replacing.
Good Luck and let me know how it turns out.
May 11, 2009 | Amana DLE330RAW Electric Dryer
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Maytag Neptune MDE5500AY Electric Dryer Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
