My monitor wwas on then off and all connections are good and the power button is flashing green?
    Genius:
  • 1,354 Answers
It is display issue just go to bios from there change the display setting
Posted on May 12, 2010
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Optiquest Q22wb computer monitor won't come on - power button flashes green then off - power is good. DVI & VGA connected/disconnected - same. Any button diagnostic sequence?
you may have a bad power supply. reon=ve the back cover and look for bad capacitors. crowned or leaking. desolder the bad ones. get new ones from an electronics parts stroe
Dec 25, 2009 | Computers & Internet
Monitor will not turn out, but the power button flashes green
try to check, that the cpu connected with the monitor,, or else,, there can be loose connection,, if stillproblem persists then it can be a motherboard, or videocard problem with your CPU
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Flashing green power button
the monitor green light comes on but the monitor itself does not come on. Sylvania LCD CL722b-Model 780
May 16, 2008 | Sylvania CL772B 17" Flat Panel LCD Monitor
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Monitor
is your monitor connected to any system? beside the power supply? Try to check the connections.. you may need to explain further of the system that you are using....
Aug 20, 2007 | Samsung SyncMaster 172N 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
