Question about Maytag MTB2176 Top Freezer Refrigerator
Refrigerator section light broke. Replacement
Refrigerator section light broke. Replacement bulbs do not fix the problem. Can it be electrical? Is there a fuss, ciruit breaker or switch somewhere?
    Problem Solver:
  • 13 Answers
Immediately when you open the fridge door the light has to go on,if it is a screw bulb,just tighten it little while'
if pin bulb push it harder,finally you may have to change
the bulb handle in the fridge.
Posted on May 12, 2010
How to change the light bulb on the ice dispenser in the door?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
First - Make sure the dispenser light switch is turned off. Now, that you have broken the bulb it is like having a bare 110 volt hot wire.
I recommend that for safety purposes you do not use either the ice or water dispenser and well as the chance of condensate from warm outside air getting into the electrical and burning out the control board or harnesses.
Get some electrical tape. Turn power off to the refrigerator at the breaker box or unplug the refrigerator. Then, tape over the broken bulb. Turn power back on to the refrigerator.
You may have a ice dispenser cup that you can remove or the dispenser frame for more ease of access.
You now may need a pair of needle nose pliers to remove the bulb.
You did not provide a model number so I can see exactly what you have. Your model number is on the inside of your fresh food section on a label on the upper inside wall.
May 10, 2015 | Kenmore Refrigerators
How do i fix christmas tree lights
Assuming the wires to be good, if the string of lights consists of more than one section (for example, a string of 100 lights is made up of two sections of 50 lights each) and the lights of only one section are out, you have a bad bulb (or possibly more than one) that must be located and replaced. If your light string is only a single section set (a set of 50 or 35 or 10), it's most likely also a bad bulb but it could also be one of the fuses located in the plug. Light sets come with a few replacement bulbs and usually two fuses. Take the plug and slide open the little compartment door and you'll see them. Replace them and try the set. If it still doesn't work, it's a bad bulb. On multiple-section sets, the fuses in the plug power all the sections, so a working section eliminates the fuses as suspect.
Dec 15, 2012 | Christmas Lights Etc Santa's Toy Truck
Light bulb replacement what size? cannot find one to fit
Most appliance take a standard bulb similar to this:
http://www.reliableparts.com/product/inv_240436702/Appliance-Light-Bulbs-461460
My experience is that most stores with a lighting section will stock replacement bulbs for ovens and refrigerators. The best thing to do is to removed the burnt out bulb and take it along with your to the store to make sure you match the replacement.
According to your manual your interior light is a 40 watt appliance bulb.
Trust this is helpful.
Apr 21, 2012 | KitchenAid KSRP25FNSS Side by Side...
I need to fix Dash air vent light -Left side - that goes on and off- How due I remove the bulb and check the wiring?
Check out the "Instrument Cluster Light Bulbs" section below:
2002 Volkswagen Passat - Repair Manual - Chassis Electrical (excerpt)
Dome/Map/Cargo Light
  1. Disconnect the negative battery cable.
  2. Remove the bulb from its retaining clip contacts. If the bulb has tapered ends, gently depress the spring clip/metal contact and disengage the light bulb, then pull it free of the two metal contacts.
To install:
  1. Before installing the light bulb into the metal contacts, ensure that all electrical conducting surfaces are free of corrosion or dirt.
  2. Insert the bulb into the holder. If the contacts have small holes, be sure that the tapered ends of the bulb are situated in them.
  3. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it is faulty or there is a problem in the bulb circuit or switch. Correct as necessary.
  4. Install the cover until its retaining tabs are properly engaged.
  5. Connect the negative battery cable.
The instrument clusters installed on these models are one of 2 types and distinguished by the instrument lighting color, either green or blue.
On models with green instrumentation, only the control light bulbs are replaceable. Should any other failure occur, the instrument cluster must be replaced.
On models with blue instrumentation, none of the components are replaceable. Should a failure occur, the instrument cluster must be replaced.
Map Lights
  2. Remove the bulb from its electrical connector.
  3. Installation is the reverse of removal.
Feb 19, 2011 | 2002 Volkswagen Passat
Replaced 30 watt bulb in refrigerator section with 25 watt bulb still will not light otherwise working well, my be switch . freezer section light works
Either the door switch or the light socket is bad. Disconnect the refrigerator and pull the switch out and test it with an ohmmeter for continuity.
Jan 06, 2011 | Samsung RB2155SH Bottom Freezer...
My light bulb broke in my aloha ceiling fan where can i find a replacement
Ceiling fan lamps are typically a low profile lamp. They can be found in most building supply stores .. l;ook in the lamp section or the lights, fan section of the store . The lamp package will be marked for ceiling fan use.
Please Vote !
Mar 27, 2010 | Aloha Housewares (93645) Ceiling Fan
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Maytag MTB2176 Top Freezer Refrigerator Logo
247 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
