Question about Jandy Aqualink Rs4 One Touch Control System Control System
Not getting a water temp system just states OPEN
  • 990 Answers
Your temp sensor is mounted in the plumbing and you will need to check the wires from it back to the control and check the connection at the board. If they are bad or worn you will need to replace the sensor.
Posted on May 13, 2010
Why is my water sensor open
Do you mean your heater is saying water sensor open? Or your control?
Whichever one it is , simply replace the sensor, if it's the system giving you this msg the. Find a probe with a bandclamp on your plumbing and replace it .
If it's the heater giving the code then depending on what type heater you have, the temp sensor is located around the header area
Mar 07, 2015 | Jandy Aqualink Rs4 One Touch Control...
Air lock cooling system
Not sure I follow your wording on the different temps. If the system is full of coolant and working correctly, the thermostat should open at 195 degrees which would be several miles down the road. Once the thermostat opens both radiator hoses should be warm. If the water pump is not working the engine will get hot very quickly.
Have you tried running without the thermostat to see what happens ?
Mar 05, 2014 | Hyundai Elantra Cars & Trucks
Error code tankless gas
E2 is a cold water inlet temp sensor. Has your unit experienced any freezing conditions? If it senses below 36 degrees or above 90 degrees it will show this error.
If its normal temp, and you still get this error...check your sensor. Its an 8(kohm) sensor. Make sure its not open. If it reads ok and your temp is not an issue, then you probably have a bad control board
Dec 15, 2013 | Bosch AquaStar 2400ES-NG
I have a 2003 alero with the v-6 what happened was driving down the road the heater works fine. then all of a sudden it was blowing cold air and the temp gauge started climbing. it started blowing how air...
Sounds like the water pump is cavitating . Replace water pump. Check coolant level also. Open the bleeder valve usually located on thermostat housing to remove air from system. close valve when coolant is present while filling. close radiator cap and top off recovery bottle to correct level. These engines are prone to overheating, do not let temp gauge get in the red.
May 01, 2017 | 2003 Oldsmobile Alero
I bought a used Goldline aqua logic system from a friend that moved and it was working fine.I think I am missing something like a Hayward Goldline Water/Air/Solar Temp Sensor GLX-PC-12KIT.On my system
You will need two temp sensors, one for water(two wires) and one for air(the other two wires). Look at the board and you should be able to see it labeled.
Apr 06, 2017 | Pool & Spa
My 2006 GMC Yukon XL Denali 6.0L is over heating and the interior heat does not work. Is this the water pump or is there a thermostat sticking? I'm in the mountains and thought maybe something was frozen...
overheating can be caused by stuck shut t-stat but u would have heat at-stat stuck open no overheating and no heat. a waterpump that the impeller broke or rotted of can cause your problem but rarly seen does your fan work or any leakage or low coolant can cause air pocket and overheating no heat. let me know and we go foward
Feb 10, 2010 | 2006 GMC Yukon Xl Denali
GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Jan 21, 2010 | Washing Machines
Oil and water on floor near upright freezer
Possible you have a sealed system problem, although you state it is working now. Maybe an overflow from drain pan is why there is water again.
Apr 26, 2009 | Kenmore Freezers
Temp guage runs in the red! 93 mark VIII 135K miles
has the water pump been changed recently? The water pump on a 4.6L 2v and 4.6L 4v look the same but are different
Apr 18, 2009 | 1993 Lincoln Mark VIII
Freezer problem
Resistance range for the sensor? I honestly don't know. I would have to determine exactly what part number, locate a manual etc.
In reality, it doesnt matter though for the purpose of diagnostics in this situation.
If the sensor is open at room temp and at 32 degrees, you have a bad sensor.
(some sensors close at call of operation, some open at call, so one cannot always go by the "if its open at room temp, its bad" assumption.)
Get a glass of water filled with ice, stir a little. You will have 32 degree water. (Water changes state at precicely 32 degrees.)
Place the sensor end in the water. If its still open after a few seconds, replace the sensor.
Dec 13, 2008 | Refrigerators
Jandy Aqualink Rs4 One Touch Control System Control System Logo
174 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
